91 Vfr Fork Swap
Good luck :)
[image: uploadfromtaptalk1352055896480.jpg]
Good idea :)You'd probably be better off buying a new pair of springs... OEM ones will be quite weak.
I bought a pair of Wilbers and some 15W oil.
Quite heavy oil but very good on twisted, bumpy roads :D
Just pre-load your existing forks with some spacers on top of the springs (I've used 2 pence pieces on older bikes before now - as for cost, around 8p a side!). I imagine lots of people will slate this cheap-skate idea - lol
That's just what I did combined with a lot of experimenting with oil thickness :)
Get 1994 CBR600 F2 of F3 forks and you will have preload adjustment and rebound damping.
Would i not also have to change brakes and wheels to do this or would it just be the forks? and are they not slightly shorter than the OEM VFR forks? I was reading up on the interweb somewhere about this and it said something like this but it was a while ago and i can't really remember.
The cheaper the better but as i said the only place i've found new parts is CMSNL and they charge a fortune. have been trawling the bay for second hand parts but they're all whole forks and unwilling to break em to sell me what i want. in terms of fork oil, when i changed the really rotten seals i said i'd stick with stock oil 10W as i wanted to see what it'd be like stock but i am considering 15W on next change.
Ah sorry i see what you mean now, forget the adjusters all together and do it internally. I would do this only i tried it on cb-1 forks and blew the aluminium head off goin round a round about, that was not fun and something i do not wish to happen again. :rolleyes:
There is a 1994 CBR600 F2 for sale here with a blown motor, I'm toying with getting. Seeing as I would have the whole bike I could use the wheel and brakes ect. How much shorter are the forks though? I know about dropping the forks 10mm on the VFR anyway, but are they even shorter than that? ThanksGet 1994 CBR600 F2 of F3 forks and you will have preload adjustment and rebound damping.
By mix and matching parts with the VFR forks you end up with a fork that has the same length and suspension travel as a stock VFR fork.
http://www.vfrdiscus...in-gen-3-forks/
Top VFR750FP, bottom CBR600 F3
I haven't measured them accurately, maybe because by eyeballing I thought they were the same length. I did take the above pic of both fork legs.
I still have a pair of F3 stanchions and they measure 633mm in length, maybe you have notes on RC36 stanchions?
As you can see in the above pic the CBR & VFR fork lowers are the same so you can keep the VFR wheel, brakes and fender.Would i not also have to change brakes and wheels to do this or would it just be the forks? and are they not slightly shorter than the OEM VFR forks? I was reading up on the interweb somewhere about this and it said something like this but it was a while ago and i can't really remember.
This discussion of the "F3 fork swap" brought be back to the heady days of the "Big List" and all that went on then in the dark days before VFRD.
Anyway, IIRC, before I ended up doing the VTR fork swap, I looked into the other popular swap at the time, which was to use F3 forks. As partially memorialised on that Web page, my understanding at the time was that the F3 forks were slightly longer (not a big problem--you just allow the forks to slide up through the triples) and that the OEM front fender could be used, but two of the mounting holes did not line up (easily fixed with some small brackets--or the use of the F3 mudguard). Found an old page on the swap, here. He says the OEM fender can be used so long as you open up the mounting holes with a file.
My data, gleaned from replacement fork tube manufacturers' fitment charts on the Web, says that the VFR750F fork tubes are 628mm long and the F3 tubes are 633mm long (agreeing with yours). Of course, the same data also says the VTR forks are 5mm longer as well... :huh: I suppose the difference I measured could have been due to (much) shorter lowers. Measuring assembled forks is a bit of an art, due to the different lengths you can measure, depending on how they're adjusted when you do it.
So, if one decides to do the VTR fork swap including the calipers. What about the discs
I am now looking for F3 forks as there are going to be a lot more of them and my front fender is manky anyway so i wouldn't mind changing that out. if it was a thing that i wanted to keep OEM as much as possible i wouldn't just for value on the bike but as i plan to keep it for the rest of my life i don't think that'll be a problem could always just hang onto all oem parts anyway.
It would be great, if you describe the process with pics :)
I used a VFR750FR-V front wheel on my VTR fork conversion, and could have used the rotors/discs as well, but ended up using CBR900RRR-V discs (which are the same size). VTR1000F discs are the same size as well.
Thanks :)Btw, the CBR600F3 (in US-spec terminology) is a CBR600FS-W (in ROW-spec terminology).
Wow, that sounds great!First generation Kawasaki ZX-12R front is a direct swap! You get preload,compression and rebound adjustibility and 320mm brake discs with 6 pot brake calibers for a bonus.
Do you happen to know, where to find som docs or pics of a ZX-12R / RC36 swap? :)
This statement was brushed aside but I wouldn't discount it. It's pretty darn easy to unscrew the top of the fork tube and add / remove a spacer. PVC pipe is plenty strong and can be cut to size. If ALL you're after is pre-load adjustment as your original post suggested you could accomplish this for less than $5.00 (or pounds sterling or whatever...).
That being said, there are lots of great reasons to do a fork swap. I just don't think pre-load is one of them.
How are 43U (upside-down) forks a direct swap?
