Sure, here's the parts needed.
-2004-2006 Yamaha R1 Front wheel
-" " Brakes (rotors, calipers and master cylinder)
-" " Forks
-" " front axle and spacers (get two extra right and left wheel spacers to make custom 2mm spacers)
-" " front fender
-CBR929/954 upper and lower triple
-New bearings for the CBR steering stem. Mine came with new bearings on still in the plastic, I got lucky.
-Custom rotor bolts. These are what you need https://www.instockf...word=9080037083
-2mm spacers to got between the rotor and front wheel
-2mm spacers for front axle (used the two extra Yamaha front axle spacers noted above and get them machined down to 2mm using the larger end of -the spacer, place them between the inside of the fork and the outside of the wheel spacer)
-DANMOTO 50mm clipons (on ebay, they're priced well and look good, I placed them below the upper triple and they offer just under 1" lower reach than stock)
-HEL SS front brake lines +2"
-Misc. Yamaha seals, fasteners, screws, etc . needed for the fenders, forks, triples, calipers and everything else. This stuff is pricey since you have to -buy OEM. I was surprised I spent nearly as much on this stuff as the calipers and m/c!!!
-Paint and powder. not needed if your fine with the colors of the wheel and fender you buy. Mine were both black and that would not do on my white bike so I got the front wheel powdercoated and then put in new bearings. The front fender I painted and cleared myself with materials I had left over from when I painted my bike.
I think thats about it. I also put in new brake pads while I was in there. New grips also and I'll need a new brake lever to match the clutch but I'm in no rush for that.
Only things to note, the oil cooler will need to but moved out and down a little bit to clear the forks. Not a big deal. Use locktite and get a good torque wrench if you don't already have one. Just for safety. Hope this helps.
