I am planning some longer trips this year and I wanted to get the 90 VFR more comfortable (plus it was time for fork maintenance anyways) So I figured it was time to update and rebuild the suspension.
I ordered a modified CBR 929 rear shock, front springs, and new shim stacks for the front forks from Jaimie Daugherty
Big Thanks to Jaimie for his patience with my multiple questions on this project (First bike suspension tear-down)
[image: 703830_10151280305899127_1097110610_o.jp]
Got the bike up onto the PitBull stands and stripped the Wheels off. I will yank the rubber get the rims powder-coated black (I HATE constantly having dirty looking wheels, black will hide it better) and install some fresh Pilot 3's.
[image: 812730_10151412509859127_1285811178_o.jp]
Swapped out the rear suspension
[image: 735615_10151353188289127_387541540_o.jpg]
And Yanked the Front Forks
[image: 819171_10151412514524127_2101167010_o.jp]
[image: 793638_10151412524224127_2136299605_o.jp]
Pulled the Damping cartridge
[image: 792354_10151412535989127_1006911000_o.jp]
Removed the Damping rod and compression valve from the damping tube
[image: 856809_10151427155399127_1263974668_o.jp]
Disassembled the compression Valve assembly in preparation for swapping in Jamie's custom shim stack
[image: 841211_10151427167054127_1561544252_o.jp]
Disassembled the rebound Valve assembly in preparation to swap in Jaimie's custom shim stack
[image: 860357_10151427170724127_1817306199_o.jp]
Next step, disassemble the fork legs, re & re the oil seals and dust boots and inspect the slider "pads" for wear and determine if they have to be changed as well.
Once that is done, re-assemble, set the fork oil level and re-install the forks.
Moose
