Slowly but surely I am getting my VFR set up for waterproof USB power supplies. I got one installed tonite.
A company called http://3brpowersports.com/products.php has got just what I want but just like everything these days....they proud of their chit.
I removed all the fairings plus I removed the headlight composite from the upper fairing so I could have some access to measure for the clearance needed for the connector in the location I picked.
They call this the "Panel Tapp" Splash proof usb power port...
Using a 7/8" "boring bit" I drilled a hole and installed the port.
Here with the upper fairing installed without the headlight composite you can see it does clear.
From the battery I wrapped this spot with a triple layer of electrical tape for added protection against chafing.
Along the frame rail on the left side I zipped tied the wire to the linked brake lines.
..and then around the head stem.
I taped this connector to further help prevent any possible corrosion. I used red tape because I ran out of black. :smile:
They also have available "Tapp Capp" USB cable seal kit. You can use your own usb cable and put this waterproof seal on it. They also have some pre-fabbed sealed cables also but remember I said they're proud of their chit?
Not actually going to use this cable but here's a pic to give you an idea.
