Let's begin at the beginning. A brake system is not a
sealed system. A physics principle known as Boyle's Law in a
round-about way establishes that a fluid cannot leave a container
unless air can follow it. If the vent in your gas tank plugs up, for
example, fuel will eventually stop flowing. Similarly, a brake system
is, like a fuel tank, vented to atmosphere, usually at its highest
point, the reservoir. (Ever notice that little notch?) Thus a brake
system has continuous access to air.
The Problem with Moisture But that means it also has continuous access
to moisture, for air naturally has moisture in it, to varying degrees.
All brake systems have moisture in them, all the time, and this is
unavoidable. There are two inherent difficulties with this that brake
system designers must contend with. First, as moisture increases in
the brake fluid, it tends to collect around the system's moving parts,
particularly the pistons. If this moisture is allowed to increase, the
pistons and surrounding areas will begin corroding and brake function
will be seriously impaired. Corrosion is a big deal in brake systems,
as anyone who has restored a vintage vehicle will attest. Nasty.
The other problem with this continuous exposure to moisture is that
moisture makes the brake fluid more compressible. You don't want any
compressibility in a brake system. For every millimeter that the lever
or pedal moves, you expect a proportionate movement of the brake pads
against the disc. If you don't have that, you have an unreliable and
dangerous brake system. Unfortunately, brake fluid becomes more
compressible as it increases in water content. Water contains
hydrogen, and in response to heat cycles the brake fluid soon has air
mixed into it as well as moisture.
Consumer-Friendly Brake Fluid Brake system designers consider these
issues thoroughly. To reduce the effect of both corrosion and
compressibility, virtually all vehicle manufacturers use and specify a
kind of brake fluid that is designed to not only accept significant
amounts of moisture, but even to neutralize it by dispersing this
moisture evenly throughout the system, thus preventing its
concentration in any one area. It's actually kind of amazing what
brake fluid does, when you think about it.
What Does the D.O.T. Rating Mean? Eventually, however, because of this
designed-in moisture management, the fluid gets overloaded and must be
replaced. So important is this fluid replacement point that vehicle
manufacturers have traditionally called for a maximum of a two year
period of use of the fluid. By that time, the fluid will have started
to turn golden, then light brown, indicating that it has absorbed
progressively more moisture. Eventually, if left unchanged beyond the
recommended service interval, the fluid will become dark brown,
indicating high amounts of water absorption and thus badly
contaminated fluid.
The importance of monitoring brake fluid's water content is further
demonstrated by the fact that in the U.S., a brake fluid's most
important classification is determined by the Department of
Transportation, an arm of the National Highway Traffic Safety
Administration. The D.O.T.'s rating communicates how contaminated with
water the fluid can be and still work properly. In essence, how
consumer-friendly it is. This is where the numbers 3, 4, and 5
actually come from. The D.O.T.'s rating focuses on the compressibility
issue, and measures a brake fluid's ability to resist boiling into a
very compressible gas even when new. This of course reflects upon its
compressibility over time as well, after it has aborbed moisture and
become incrementally more compressible. This is the fluid's so-called
boiling point, which for most brake fluids centers around nearly 500
degrees Fahrenheit when new, and rapidly decreases with water content.
Incidentally, D.O.T. 3 brake fluid is for all practical purposes
obsolete. D.O.T. 4, a rating that came about in response to the
emergence of sintered metal brake pads during the early 1980s, has
replaced it, being still a glycol fluid but with a slightly higher
boiling point. Glycol brake fluid containers now are labeled "D.O.T.
3/4," presumably to eliminate confusion, as the two fluids are nearly
the same. However, this seems to have merely raised more questions in
most people's minds. The short of it is, if using purely organic
(almost exclusively aftermarket, and usually, racing) brake pads,
D.O.T. 3 will suffice. Otherwise, use D.O.T. 4.
Glycol Brake Fluids
Virtually all vehicle manufacturers specify one kind of brake fluid,
whose base is alcohol. As we have already explored, this eminently
ubiquitous alcohol (actually glycol) brake fluid is suited to the
realities of vehicle ownership. It neutralizes moisture, turns color
in direct proportion to moisture content, disperses moisture so that
it doesn't concentrate, and resists heat related degradation that
leads eventually to increased compressibility. Glycol brake fluid is
clearly extremely forgiving, maintenance-wise. In fact, vehicle
manufacturers use it because they are quite aware that the average
owner will never change his brake fluid, let alone do so at the
recommended maximum two-year intervals!
There are disadvantages to glycol brake fluid however. For one thing,
the very attribute that enables it to accept moisture actually causes
it to attract moisture, as any alcohol product will. For this reason,
brake fluid suppliers recommend that only small amounts be kept on
hand, and that a tight seal be kept on any unused fluid. (In the old
days, it used to be available only in metal cans.) Another
disadvantage, and a significant one, is that glycol fluid is
chemically caustic, meaning that it damages other materials. It
effortlessly removes paint and does strange things to plastic. (Even
after it is wiped off, glycol fluid causes catalytic embrittlement, a
chemical reaction on the molecular level that leads quickly to deep
cracks. The ABS plastic used in motorcycle bodywork is especially
susceptible.)
Silicone Brake Fluids
In years past, all brake fluids were glycol. Then D.O.T. 5, a silicone
fluid having a higher temperature rating, emerged, initially to meet
the higher boiling point requirements of racing use. (Race car brake
systems include oil-cooler-like heat exchangers and ceramic pads.)
Silicone fluid was able to withstand the most heat of any brake fluid,
so it earned a reputation as a racing brake fluid. However, silicone
brake fluid has properties very different from glycol fluid, and has
its own pros and cons. On the advantage side, silicone fluid will not
harm paint or plastic, and does not aggressively attract additional
moisture as glycol fluid does. On the disadvantage side however,
silicone fluid aerates easily. Harley-Davison, one of the sole current
OEM users of silicone fluid, warns buyers to let the fluid sit at
least an hour before using it. The trip home in the saddlebag is
enough to aerate silicone brake fluid until it looks like a freshly
poured soft drink. Silicone fluid is also slightly more compressible
than glycol fluid, does not change color to tip the user to its
moisture content, and worst of all, neither accepts or disperses
moisture, making systems using it more corrosion prone, and requiring
much more frequent fluid changes. Silicone brake fluid also lacks
glycol fluid's naturally occuring lubricity, making it incompatible
with the mechanical valving in some antilock braking systems.
A third brake fluid category could be included, if we were to consider
bicycles. Their hydraulic brake systems use mineral oil, that is, baby
oil. About the same consistency as glycol fluid, mineral oil is still
not the best thing around paint, but in most other respects it is
fairly non-corrosive. Like silicone fluid however, it does not deal
well with moisture.
Which is Best?
As you may have noticed by now, instead of looking at brake fluid as
D.O.T. 3/4 versus D.O.T. 5, we should see the issue as glycol versus
silicone. This represents the larger division of type, and comparing
D.O.T. ratings just isn't significant, especially since D.O.T. 5
fluids are now available in glycol formulation. Glycol fluids have
improved until they now meet D.O.T. 5 standards. D.O.T. 5.1 for
example, is a glycol fluid designed for certain ABS systems having
mechanically cycling proportion valves. So now we have D.O.T. 3, 4, 5,
and 5.1, with all but the 5 designation being glycol, while the 5 is
silicone.
The real way to compare brake fluids is by deciding what is important
to you. Is silicone fluid's safety around paint and plastic more
important than yearly changes and a softer action? Its higher boiling
point, the reason for its development and at one time its strong suit,
is now academic, since D.O.T. 5 glycol (5.1) fluids are now widely
available. Glycol fluid therefore is, for most of us, the better brake
fluid, and the best just may be the 5.1, if the highest boiling point,
which is really a moisture tolerance measurement, matters.
On the practical side, beware that glycol and silicone brake fluids
are hugely incompatible with each other. Mixing even small amounts
will create a sludge that looks amazingly like Italian salad dressing
and is about as effective as a brake fluid -- meaning, not. Of further
consideration is that, in some cases, the hardware designed for one
fluid will not accept the other. Brake caliper and master cylinder
seals, hoses, and other parts won't always work correctly when the
type of fluid is changed.
I'm currently using Motul 600 in all my customer's bikes...
Motul 600
Racing Brake Fluid 600 Factory Line 100% Synthetic Fluid –
DOT 4 For hydraulic actuated brake and clutch systems Very high
boiling point : 312°C / 594 °F
Motul DOT 5.1 Brake Fluid Long life 100% Synthetic Fluid For hydraulic
actuated brake and clutch systems DOT 5.1 NON SILICONE BASE Dry
boiling point 522ºF
Dry boiling point Wet boiling point 3% mositure
DOT 3 205 °C (401 °F) 140 °C (284 °F) Glycol
DOT 4 230 °C (446 °F) 155 °C (311 °F) Glycol
DOT 5 260 °C (500 °F) 180 °C (356 °F) Silicone
DOT 5.1 270 °C (518 °F) 190 °C (374 °F) Glycol
