Lots of experience and knowledge out there....what are some thoughts ? Rectifier? Just got the bike back home from tow.
Appreciate any ideas/tips...thanks
auggius is right on it
Your plugs (here the one from the Stator to the wire that goes to the RR; this one on the right side) should be free of corroson not browned.
[image: aaaaaaaaaaaaaaa.jpg]
For good measure I used a narrow tie-wrap the make sure to above would make a firm contact
I had the same thing happen to my 94. On mine, the R/R failed. It was the original one, lasted 38k, and it left a gooey black dripping mess when that black rubberized/gel-like fill heated up when it failed.
I got a new OEM R/R (they have fins now!) and swapped it out.
That one failed too. Lasted 18k miles.
I left the OEM stuff completely, and went to www.roadstercycle.com and bought their kit FH020AA for $140 + $5. It has a new R/R (and new plug & play wiring) from a Yamaha, the most stable one made, apparently.
I've had mine 18 months now without a single charging issue.
As a bonus, the new R/R mounts right up to the old OEM R/R spot, and the tail fairing still slides over it A-OK with no issues or clearance problems.
As auggius said, get the battery tested. This is the simplest and cheapest thing: it's free at most auto parts stores.
Be aware though, that a dead battery can be caused by either age of the battery OR a bad regulator or stator. So even if your battery tests bad and you replace it, you may still have a problem in the system that will kill your (new) battery (again!).
The same way, if you replace your regulator and/or stator but your battery is dead, you will still have issues. So the moral of the story is that you have 3 components plus some connectors to troubleshoot and inspect. Don't stop when you find that one of them is bad. Inspect and test them ALL and make sure to replace/repair everything that is not in spec. Otherwise, you run the risk of burning out a new component.
If you do not see the voltage across the battery increase with RPM (should be around 12-ish volts at idle and up to less than 15 at 5000rpm) then you must start troubleshooting the regulator and stator.
If you search the site, you will find thread that will tell you which connectors to unplug and how to measure the right voltages for each component. I don't remember off the top of my head, to be honest. Make sure you know how to use your multi-meter and switch it to A/C when you measure the output of the stator. :)
I found that an analog meter is not at all accurate enough to be reliable. Suggest a digital meter.
It's kind of sad that there are so many of these threads. There should be a sticky in this sub-forum to address it.
Joshua from wiremybike can make you a MOSFET one with a plg so it will fut on your 4th gen.
He made one for me. :beer:
+1 go this route ...
Come on Dutchy give some props ...
It's a great photo crop ???
That's the oem r/r so definitely worth replacing just on that point alone. I have a Ricks' r/r from Wiremybike but I don't think it's a MOSFET type one which apparently is the latest & greatest.UPDATE. Performed the stator tests from wire bike and
- have continuity between all three yellow wires
- no continuity from any yellow to ground
Battery is good...but no charge...so likely the rectifier..best prices from wiremybike? Or better yet, best quality product?
Here is a pic of my rectifier...doesn't look bad, but I guess internally it's damaged.
Be sure to check the connector to the starter relay!
Not sure where you ended up on this, but it sounded like you were assuming the R/R was bad, because the stator checked out but the bike wasn't charging. Did you check the R/R using the multimeter? Just because the bike isn't charging and the stator is good, don't make the mistake of assuming it's the R/R. Yes, they fail. But they are not the only thing that will cause that symptom.
The starter relay connector sits on top of the relay, right in front of the battery. It's easy to neglect this connector, but they also get corroded, develop high resistance, and then will heat up and even start to melt (ask me how I know). If this connector is bad, then the R/R has to shed a LOT of extra power as heat, which could cause the R/R to fail also - so they could both be bad.
Also - R/R failures can be intermittent (I've had two that were). Sometimes a failure will show up when hot, sometimes at random.
The best advice I can give: keep connectors clean, and install a VOLTMETER!
