Brought it home yesterday.
As always, every adventure is... An adventure :wacko:
It's been an hour and a half drive to the seller's place, mostly highway. Right as I got off the highway, I got stuck at the traffic light and noticed that my A/C is blowing hot air. Quick glance at the temp gauge confirmed that I was about to overheat. I turn onto a residential street that headed towards a gas station, but got stuck in a standstill traffic due to an accident ahead. Great. Just what I need.
Since the gas station was 1/2 a block ahead, I jumped onto the oncoming lane and made it in just in time to notice the PO at the scene giving me a dirty look.
Opened the hood and discovered that my trusty Flex-a-lite e-fan controller, which I've had for 4 years has given up ghost.
With the help of some wire cutters, I bypassed the controller and hooked up the fans directly to the battery.
[image: 29c82e33-1fb8-43ef-a7fb-729ce30e6dd7_zps]
Back in business.
After finalizing the deal with the seller, he helped me load the bike and all the extras. We got to talking and as it turns out, someone I know locally has been trying to buy this same bike a few month ago, but the deal fell through.
Here are some of my back home pictures.
[image: A2ADA246-E340-406D-831C-6AC0EEA57483_zps]
[image: 2FD47649-08F9-4E49-B251-5D398242A11B_zps]
[image: E7A45539-392D-484B-8CD1-A71286B725C9_zps]
[image: BA183896-1A52-44D1-8848-3D02F1844D69_zps]
The inventory of plastics. Looots of work there, but it can be done.
[image: 741AF271-6F7D-4BC3-9408-28B9E15F4759_zps]
I couldn't resist doing the initial vital checks.
After hooking up my battery, the dash came to life
[image: 7582F7C9-B441-4F34-BDB9-714B4F7D1457_zps]
Now, is the engine turning? The oil was pristinely clean, as was the antifreeze. Still, I decided to turn it by hand firs, just in case.
[image: C1F6C809-E310-475C-80FF-4D354BF701C0_zps]
The first attempt resulted in a very unpleasant scratching noise coming from what I thing was the forward cylinder bank (I could be wrong here). Almost felt like the piston was trying to overcome rust.
I then removed plugs, which were all in good order showing just the right amount of soot and sprayed some wd40 in all cylinders. After a few minutes, the motor turned over w/o any(much) drama. I am hoping here for this particular problem to just heal itself once I get it running.
Next came the air box and what I was almost sure, a mouse house.
But, a pleasant surprise awaited. Not only was the mouse not in residence, but there was a very serviceable K&N filter.
[image: 579D45D5-77A2-4A83-B78E-72C3880ECB6D_zps]
The venturi's (?) were perfectly clean w/o any signs of dirt or rust.
[image: C9A0E260-2E65-4C09-81D0-25E18F68F3C3_zps]
All good news so far. :cheerleader:
Then it was time to check out electrics.
All fuses are intact.
[image: E8D9D564-A17A-4D20-A5BD-C3A7EB345C96_zps]
One is missing (either turn signal or headlight), couple are incorrect, but it's a start.
The rectum fryer is fried as expected.
[image: 526A162E-43C0-433F-8284-7372F719DA5C_zps]
[image: 440040D7-0BD8-4CE0-8FFA-FFE9AB721A78_zps]
The starter relay and its plugs are toast as well. Probably.
[image: DBAB5067-03D7-4676-970D-7599013C733C_zps]
I was able to turn the motor with the starter bypassing this minor disaster.
Below is something that was a blessing in disguise.
[image: CA2D538F-6CAF-4EB7-8E63-54DC3A7D0A35_zps]
Someone had cut the fuel line to the pump as part of long-term storage maintenance.
You wana know how to prep your bike for the winter? That's how it's done, kids.
And I sure was thankful to whomever done it, 'coz the tank was perfectly clean inside. This was an unexpected bonus. I was honestly preparing myself for dealing with muriatic acid and POR15. Not something I'd choose to do for fun.
But before I could make that discovery, I had to get the tank opened first.
The key that works in the ignition does not fit the tank or the helmet lock - Seat lock is missing.
[image: 43C80F77-9BF1-4A9E-BB05-C84F7750AC94_zps]
The next picture portrays violence and mutilation.
[image: 0ACB9410-7B08-4607-A687-5765CEB75144_zps]
But the tank is open
[image: 308AE35C-7520-4422-8F30-1718B8760417_zps]
Right now, I am drying the tank after the wash down.
[image: 3D9CC508-128A-4593-AE74-07933952032B_zps]
My next steps will be to get the beastie running and rolling under its own power.
Cosmetics will have to wait until winter. I tend to have more patience to tinker with sanding and painting when I got nothing better to do.
