Need Verification
Yes, headers have to be removed.
I guess you really have to want it gone in a big way to go to so much trouble / work. :mellow:
That's what I figured. I'll wait until I get time and put on the cat-less headers at the same time.
My goal is to lighten the bike up as much as I can without going too crazy and since I have the PitBull stand and this is my play/track bike, the center stand can go IMO. The stock exhaust was replaced by a 2Bros CF can, so I lost a bit of weight already!
Even without cats! I tried it once and the right side won't come out far enough with headers installed.
Well crap, I was going to take mine off and give it a new coat of black paint! :mad:
You just need to get creative with masking tape and paper, and spray things in-place! If you can't get at a surface easily then there's a good chance you won't be able to see it on the bike either. I did this with my headers and was very happy with the result:effort ratio.
This is why they make cutoff wheels for die grinders & Dremels.
Another confirmation/verification or more or less seeing what others have done. If I remove the rear passenger pegs, the left one has the rear seat latch and helmet lock as part of the whole unit. Apart from cutting the peg portion off, is there an easy way to retain the seat lock portion? Is there possibly another bikes lock assembly that I could use?
