The guy who made it is one of the Hungarian VFR club's member and made a lot of VFR's from the club. He is a motorcycle mechanic. If there would be any problem with the diaghragms he would have said that and would not assemble back that in. I was also next to him so I saw everything. I don't think that the problem would be there. I went to him to adjust the valve clearances and carb cleaning-adjustment. I said to him that " I can't overpass 6k because the clutch slips".
Hey Dudes,
It seems that the pump works like hell, it blow so much lifegiving liquid that I could water my garden with this pump.
Here's some pics.
http://kepfeltoltes....ltoltes.hu_.jpg
I hear some suck-voice if I pull the throttle, but that's because of my K&N air filter.
The diaphragms were OK when the guy was adjusting the carbs. Also the same was the situation before he diassembled them.
OK, so you've seen the diaphragms actually move the same distance at the speed when running? Have you actually lifted the diaphragms yourself and watched them drop at the same speed when released? I ask because you said the problem existed before the carb work, yet the guy released the bike back to you after working on the carbs and not fixing the problem.
Do you have an external fuel filter? If so, was fuel flowing through it when you checked that the correct volume was coming out of the pump? Actually, there should be a filter screen in the tank, so take off any external fuel filter and see if that fixes the problem.
After all that, we can move on.
Cheers,
Glenn
There is an external fuel filter but in the in line of the pump. If there would be any problems with that, I think I wouldn't have the proper quantity of fuel in it out line. Am I right? To make sure no problem with that, I can try to clean that.
I've also checked the right back spark plug (just this one) and it seems OK.
Yes, that would seem to be right, BUT just because the obvious things are not working out it would be good to bypass the fuel filter completely so there is no doubt at all about it.
Are you sure your fuel line is routed to the carbs in such a way that there is no kinking or narrowing that could restrict flow? That very scenario is very common on the Triumph Trophy.
Next steps may be to run it with the fuel pump relay jumpered to ensure continuous operation. That would eliminate the possibility of a bad relay. Then if that doesn't resolve it, you may want to check the float heights.
The classic symptom of a slipping clutch is "free" revving at higher RPM in top gear. Did yours free-rev past 6000 when the clutch started slipping or did it even then not rev past 6000?
Did it ever run correctly for you? Could there be a problem that was caused by a previous owner like the cam timing being off by one tooth, maybe?
Keep us informed, please.
Cheers,
Glenn
