Vf1000R Cyllinders On A Vfr800Fi?
33 posts Started 9 Sep 2015 Last recovered post 11 Mar 2016 Wayback Machine snapshot 13 Apr 2016
Hi.
Has anyone tryed to fit the cyllinders from a vf1000r on a vfr800fi? or can it not be don?
I highly doubt it. Considering it's been 17 years since the 800 came out, and a liter bike is what every vfr owner dreams of, someone would have tried it. Not sure but aren't the gear drives located in different spots. (800 on the end,1000 in the centre)
I wish it was a bolt on mod.
have you not been reading highsidenz's thread?
Fill us in please. Did a search and found his fifth/sixth gen swap but nothing about a 1000 r.
If I win the lottery, I'll get someone to cast me new cylinder blocks with room for 1000cc sleeves...
Hey, anyone in for a group buy?
Thanks Cogswell.
Now that's dedication, wow.
I remembered reading this post in the beginning, but lost track. Very interesting.
The VFR cylinders are cast as a whole with the upper crankcase half.
Not like an inline-4 where they bolt onto crankcase.
Therefore, not swappable.
Hi Madsen
Don't think you can get anywhere near 1000cc with the VFR800 configuration.
You'd need to go to 81.4mm bore to get to 999cc with the standard stroke of 48mm.
With that bore you'd have pretty much no water jacket left once you put pressed in sleeves etc.
Sorry but if you want a litre bike, you are looking in the wrong place here with the VFR.
Not saying that it could not be done but piston mass/balance factor etc. would be well outside the original design.
On the same note I was wondering if it was possible to up the compression ratio by decking the heads. That might make the bike stronger on the bottom like we all want. Guess there could be issues with the gears though
Can't shave the heads with the gear drive cams. VTEC yeah you could do it because of the cam chains.
Another thing, boring the existing VFR 800 cases to 1000cc would probably have you carving through the water jackets I think. There's not a lot of metal there. Hence the MMC liners for strength and wear resistance.
Forced induction!  A proven commodity, with a certain cache`.  R3~
Well, there was this . . .  :wink:
http://www.vfrdiscus...d-8th-gen-vfrs/
Thanks for all answers. It was just a thought I had one evening I was bored. I think I have to try and mount the intyre engine from a VF1000R if I want a 1-liter VFR800 :cool:   We are getting closer to Winter here in Denmark, so lets see what time will bring :goofy:
Well, as HighsideNZ built my 825cc idea, we know that's possible, but whilst it gives 140hp, it does not appear any stronger low down, when I compare dyno graphs with my own.
I have been thinking some more & you could build a 916cc VFR, by boring out the MMC liner & replating the cylinder wall with Nikasil or equivalent. That would leave 5mm wall thickness compared to 8mm as standard. There is room to add a 1 or 2mm reinforcing ring, or you could add an open desk support, machined to fit.
This would use CBR1000RR 78mm Wiseco pistons, they are the same weight as standard, so could use standard rods & rev limit, alternately, you could get some new rods made up & increase the Rev limit.
You would need new more aggressive cams to compensate for the higher compression ratio, this setup should produce around 180hp !
We know the engine can take this, the RC45 racers were making this kind of hp & the supercharged ones can be tuned to similar numbers, so it's strong enough. Might want to weld or pin the crank webs, but I don't recall that being done to the race bikes, so should be OK. This setup should be stronger low down to.
All you need now is a bucket of money & a good engineering shop ;)
If I ever get the spare cash I'm going to build this, just to prove that the RCV213S could have been built years ago for a lot less money !
Sorry but there is another issue to remember when going extremely large in the bore.
The water jacket holes in the head around the bores are going to be really close to the edge of the gasket/cylinder bore, so I'd bee rather concerned about leakage to/from the water jacket.
I've just measured an old gasket and by the time the gasket bore is increased to 79mm there would only be 3mm from the inner edge of the holes in the gasket to the actual cylinder bore.
Seeing the casting holes in the head are quite a bit larger than the holes in the gasket, then I'd have to say that there would be not enough meat to guarantee a good seal.
Phil
Mohawk, that will be a costly way to go :unsure:  Maybe I can try an find a supercharger kit, but they are hard to find. I have looked but can not find it.
Don't you wish we could just slap these in the vfr? That would also greatly strengthen the block by going from open deck to closed deck and it would also possibly allow better head gasket sealing, as you could o-ring the block and heads....
http://products.vivi...-150775455.html
CR, Back to start of thread vf1000r cylinders in VFR !
Phil, good point I have not looked at the head cooling voids, just the open deck, will need to do some measuring !
CR
That is pretty much what I did with my old VF750 based 880 back in the '80.
Machined the existing liners out completely and made up my own with tops to fit recesses in the block.
Made them out of cylindically cast cast iron. Similar to what you posted.
Phil
The bores stood up well but I made my own gear drive for the cams and I had real problems getting that to hold together.
Cost me a lot in bent Ti valves.
Shelved it in the end.
Moral of the story, try again with a sixth gen :D
Wasn't possible back in '84 so hence why I've done what i've done with the Gen5/Gen6 scenario now.
There is a shite load of power waiting to be tapped this these engines.
I need to buy a spare 6th gen engine and get to work. I have got a lot of catching up to do lol.
Late to the party on this one, but a subject that hasn't been mentioned is longevity.
I'm thinking primarily of things like the cooling system and the cylinder wall thickness.
Since supercharging doesn't alter the engine itself, all of the components maintain their stock strength/capabilities.
As Mohawk stated, we know that the engine is strong enough to deal with the HP that RC45 racers were getting, but they looked at the situation with an eye towards a longevity of one season.
I'm the furthest thing from an expert on any of this stuff, but logic would indicate that you'd have to address whether or not the cooling system and the thinner cylinder liners could handle the increased heat.
This makes me wonder. Does anyone know how many Toro chargers were installed, and how many are still running? Of the few I've read about, I don't remember any failures. Just a severed finger, ouch.
Member named zRoYz has your answer.
ggatagan, you are correct re longevity, but remember in a road context they are not used at full capacity all or even much of the time compared with a race bike that apart from warm up is caned everywhere all the time. So it's all relative. I'm having to tweak the fuelling on mine to control temps in certain parts of the Rev range.
We are just getting in to the warmer weather down here in NZ so it will be interesting to see how the 825 holds up this summer.
Currently, if I get stuck in traffic, the temp rises to 106 and the fan cuts in and it falls quite quickly to 96.
If the temp is a problem this summer I think i'll build a front rad set and get rid of the side units.
As my pipes are close in on the engine with the bottom rad hose in front of them, I have a fair amount of room to fit a bottom rad so should be able to get plenty of area.
Time will tell.
If I'm getting stuck in at present the temp sits around a constant 85 so that's not too bad.
Would be better down around 75 though.
Cheers
Phil
Hey, I'v just been talking to a mate who has a 2006 CBR1000RR radiator.
Looking at the picks it may well fit as a front rad for the 825.
I might have it in my hand in a couple of weeks as it is right down the other end of the country.
I'll start a new topic once I have the rad to start to see if it will fit.
Cheers
Phil
You could've added a second engine for less than that.
This has really got me wanting to pick up a second engine lol.
End of thread · 33 posts recovered Wayback Machine snapshot 13 Apr 2016
