23 hours ago, Trevor
Again, there are no geometry changes here. The only time geometry changes is if you use sports bike triples with a smaller offset than VFR triples, like CBR/SP1 etc are 30mm vs the VFR being 40mm.
Well that's NOT quite correct. There are 3 components to frontend geometry, they are offset, which is created by the triple T's, plus rake the angle of the forks measured relative to the Vertical & trail, the castor effect of the front wheel, which is determined by a combination of the offset+rake+wheel diameter.
Manufacturers state in their literature the default dimensiosn they designed the bike to, these are often NOT correct when measured. But regardless, if you have a bike then you have these 3 measurements in use empirically.
If you push the forks up through the T's then this alters both the rake & trail. If you pushed the standard forks up 20mm or fitted 20mm shorter forks then you have adjusted the rake & trail together by the same amount regarless. So there is a change in geometery when fitting the shorter CBR forks.
That said the VFR's have a quite conservative geometery to allow for loading with a pillion & luggage, I'm sure you have all noticed how carrying a pillion changes the way the bike handles, its more to do with a more relaxed geometry than the weight. Weight on the rear, lowers the rear ride height which in turn increase the rake & trail (think chopper here) making the steering slower.
Shortening the length of the front forks, or raising the rear of the bike (which has the same effect) makes the rake angle steeper & shortens the trail (trail being the self centering castor effect of the wheel) this makes the bike handle or rather change direction quicker, which is caused by the moment of precession. Precession (https://en.wikipedia.org/wiki/Precession) is what allows a bike to turn, the closer you bring this to the ideal angle the less effort it will take to steer, but conversely the less stable the bike will become & the more sensitive it will be to external forces deflecting the front wheel.
On a sports bike the geometry is set closer to the ideal & thus making major changes to their geometry, leads to the much published "Tank Slapper" effect where the front wheel when light & hitting a bump, can slam from lock to lock. the VFR has a very conservative geometry, so can tolerate much larger changes, like a 20mm shorter front fork without becoming nervous, though you will notice the change when it comes to the effort required to steer the bike, this is a GOOD thing.
Now just get on & get it done :)
