What are your opinions on the frame sliders available for the 8th gen? Have you installed them? I hope not, but have you had to use them? Please share any info you may have. TIA
Frame Sliders For 8Th Gen
Not sure that helps but I bought the ebay costly frame sliders.
Wil install them later this week.
They look sturdy and well made.
Which ones are those?Not sure that helps but I bought the ebay costly frame sliders.
I've only seen R&G ones
From T-REX, seems to be a US company. At least they shipped from the US.
http://www.ebay.com/...CxT3A8l&vxp=mtr
They are indeed, in Texas. As it happens I also ordered these a few days ago but they've not arrived yet, not surprisingly. More expensive than R&Gs but no 28mm holes needed in the side fairings either.
http://t-rex-racing....og.php?item=562
I have the T Rex installed. Hope to never test them, but they look like a quality good.
Do they affect how the fairings fit?I have the T Rex installed. Hope to never test them, but they look like a quality good.
- [image: Attached File] image.jpeg 40.71KB 10 downloads
- [image: Attached File] image.jpeg 43.63KB 10 downloads
- [image: Attached File] image.jpeg 42.04KB 10 downloads
i have also mounted the front ale slider by R&G
the frame on the 6 gen has a slightly different bolt pattern i take it? thus the t-rex wouldn't fit?
They make cut and no-cut sliders for 6th gens too. I think the plastics are the difference.
http://www.t-rex-rac... VTEC/2002-2009
I´ve fitted the GSG sliders. No need to cut the fairing. Nice finish. Greetings Jens
http://www.gsg-mototechnik.de/
- [image: Attached File] IMG_1658.JPG 52.57KB 12 downloads
- [image: Attached File] IMG_1646.JPG 41.76KB 10 downloads
I did install my TREX frame sliders today.
THey don't look sturdy they are really sturdy.
Mounting was a piece a cake. Only challenge was to remove the fairing..
I actually didn't remove fully the fairing. I just unscrewed all screws and that's all.
I did take a bit late. It was too dark to take reasonnable pics. Will do that tomorrow.
received kit :
sliders mounted :
Ok, I know, poor pics and dirty bike... but could be worse taken into consideration the Paris weather !
:angry:
Thanks for the pics sdouble, how long did it take? :unsure:
It took me a little more than 1 hour. I didn't remove the fairing fully. I do think that it could be much faster if you are used to remove the fairing.
I rode the bike today and I must say that those sliders are not as well designed as I expected.
The spacers for the bracket are too long. Due to that, the boots hit the bracket when I change gear or when I brake... not as happy with that product as I expected...
I may get used to that... I'll see and report.
T Rex does not change how the fairing fits.
My boot hit the T-REX bracket
I suggest not to buy the T-REX frame sliders currently. I contacted T-REX and it seems that they are working on an upgrade.
Curently, the design of the bracket and its spacer prevent from shifting up properly
Does that mean they will replace yours (and mine, due here tomorrow)?
I hope so.
THis design issue is really a pitty because that product is really of rather good quality.
Have you got any other pics?
The GSG site doesn't really explain how they fit together
The base plate is bolted to the frame. There`s a adapter brace bolted to the base plate. This adapter fits into the vent of the side fairing an can be easily removed (f.e. to remove the fairing). The base plate remains bolted to the frame. The adapter is for energy absorption. Bolted to the adapter is a slider which can be easily removed and renewed in case of a minor damage. See pics.
- [image: Attached File] IMG_1928.JPG 41.85KB 8 downloads
- [image: Attached File] IMG_1929.JPG 44.23KB 8 downloads
- [image: Attached File] IMG_1930.JPG 24.9KB 8 downloads
- [image: Attached File] IMG_1931.JPG 17.95KB 7 downloads
- [image: Attached File] IMG_1933.JPG 31.36KB 8 downloads
- [image: Attached File] IMG_1936.jpg 17.98KB 8 downloads
I don't know if the 8th Gen is different in different countries or not but in the USA, the TREX install and works beautifully with zero shift issues. My fiancé and I both have the Gen 8 VFR800 with the TREX sliders and have never experienced any shift issues.
That's interesting.
Do you have pics of the bike with the sliders mounted ?
For me, your statement is rather strange.
Do you manage to grad and fold easily the side stand when you are on the bike ?
Could you confirm that your shin does not hit the slider bracket when trying to up-shift ?
Jens How much were your sliders?
Hi guys here is a pic with my leg on the bike
https://mega.nz/#!4I..._M2hNzqM7DxCye8
You can see that I can't shift with the proper part of the boot.
The braket of the slider blocks my leg,
I don't suppose there's any chance you may have installed the bracket upside-down?
(Sorry, can't download your image- using a Mac. And, Homey don't do Flash.)
completely impossible
No such problem here. I'll see if I can get a pic when it is light out tomorrow.
How can I post pictures on this forum? I would like to share pictures of our Trex sliders but can't figure out how to do it. I am having no luck in pasting a link for some reason.
My shin shoot the braket at the very location where you put something which may be an electric cable. Prevent from shifting properly where i wear boots, and is pretty painful when I don't.
How tall are you ? I'm 6'1"
I'm 5'8 and have no problem. The cable is for my heated vest, kind of cold these days.
update from T-REX.
They did some re-design of the kit. They are going to ship one set today.
I should receive the sliders within, say, 1 week...
Got around to fitting mine today and can report that I don't find the same problem that sdouble has posted about above. However, as you can see in the pic there's not a great deal of clearance between leg and bracket but at 5'10" I'm 3" shorter than he is and if my legs were longer and my knees further forward my shin might well be in contact like his.
As you see, to keep the winter at bay I've also painted the bolt heads with black metal paint before installing and used Pro-Bolt's black alloy socket cap covers to tidy things up a bit.
Hopefully I won't be testing them. :wacko:
- [image: Attached File] 2016_0123Pix0013.JPG 54.31KB 11 downloads
could you try to shift up a gear and report ?
it seems that they provided you with more suitable screws than what I got
After going through 5 bikes so far and maybe six sooner or later I've learned when getting a new or new used bike to just go ahead and drop it, fix it, and get it over with. It isn't if but when and how. :laugh:
Exactly, there's only two types of biker, those who have dropped their bikes and those who are going to.
Which is why we buy sliders... :happy:
For sdouble - I rode it in to work this morning, boot does occasionally make contact with bracket as I'm moving about but not when changing up or down. I think the bolts I have were exactly the same but I added these...
https://www.pro-bolt...ack-x-10-7.html
Received today the re-designed frame sliders from T-REX.
Basicaly, the spacer are much shorter and the main part (L-shaped bracket) is strongly modified
http://https://mega....cekyoy8hT4LS6bk
https://mega.nz/#!QQ...VL7UBjZ5v-lr8JE
I'll get that mounted this week end but at first glance, that new design seems to me much more clever.
Club Racer. Please post some pics when you get them installed. Top view and side view so we can see how far they stick out compared to the old design. Thanks
So they've taken the corner off the puck mount and removed the front section from the back plate? I assume the slider bolts now come from the inside as those bolts can't be seen in your pictures? They certainly look sleeker but I'm not sure how much of an improvement it will be, seeing as the thing your leg makes contact with is the rear corner of the back plate which has to be pretty much in the same place, lined up with the upper bolt. I suppose the sliders have to stick out the same distance to get outside the fairing. Still, if not having the front bolt means the plate doesn't need so much clearance and the spacers can be shorter bringing the corner further in, it might make a difference. Let us know!
totally from an outsider's perspective here, but they sure look weaker... :unsure:
I doubt... they are still rather sturdy
Embarrassing... :wacko: ...
No mounting instructions. Obviously they bolt differently than the previous version.
Didn't find a proper way to mount the new sliders onto the bracket.
waiting for an update from T-Rex
I recently installed these and like them for the most part. Only issue I run into is that my shin will hit the bracket when I down shift if my foot is too far forward on the peg. I'm getting used to positioning my foot correctly but if the bracket was slightly forward I probably wouldn't have any issue.
I see that we are facing the very same problem :beer:
Have you fitted your new ones yet?
If so any improvement?
Funny story... I received quicly a new set of sliders... But, they obviously mount differently...
I've been asking for mounting instruction for weeks... no answer....
strange company...
T-rex here, pics in gallery. Hard to really tell they're there, but would rather have them than not. Preferred not cutting the fairings, too.
They do bump my shins every so often but you get used to having them there and can accommodate. :) I'm 6' FWIW.
Photo attached...
VFR Front
[image: VFR 3/4 - Sunset]
VFR 3/4 - Sunset
Looks like the GSG ones from Germany are the better option.
They have distributors in the USA too.
I have the T-Rex sliders and yes i used them and they performed as advertised. Kept most of the weight off my leg, yes i hung on during the slide.
I have no issues with the shifter with my T-Rex sliders on my 14 VFR 800
- [image: Attached File] image.jpeg 65.07KB 3 downloads
- [image: Attached File] image.jpeg 45.13KB 3 downloads
To view your picture on my Kindle requires downloading a plugin. Ain't gonna happen, which is a shame because I'd like to see it.
to Pjcliffo :
afaik, you're the first one who fitted the new release of the trex sliders
did you get any instruction for mounting them properly ?
It's not too hard. You can see from pics the 2 bolts to use. Take out one at a time then choose the T. rex bolt that with the spacer is the same length. It's not too hard to figure out which bolt and spacer goes where. Then do them up to the same tightness. No need to cut or remove fairings. They seem very solid and a nice fit.
