Orange Box
8 posts Started 30 Mar 2016 Last recovered post 31 Mar 2016 Wayback Machine snapshot 1 Apr 2016
So the winter hibernation has come to an end. I need to clean the orange box where the wires go into. What's the easiest way to do this?
Not sure why my pics didn't post.
  • [image: 20160329_133826.jpg]
  • [image: 20160329_133830.jpg]
I could be wrong but it may be possible to remove the orange connector from the wires and replace just the plastic part. There are release catches that secure the wire ends inside the orange bit. I've seen special tools designed to do that. I've done a couple with a small screwdriver blade. Took me a while to figure some out and some defeated me completely. I obviously need some of those special tools. Unfortunately, my memory fails me as to where I saw them.
Joshua at wiremybike dot com has been very helpful to me by email.
That's the infamous ground terminal.  Some people eliminate future corrosion problems by cutting off the connector and soldering all of the wires together.  You just have to have a big soldering iron, or gun, or torch...
Get rid of it.
Solder all the wires together, and add a larger gauge earth straight back to the negative side of the battery.
This is a known weak spot that will cause future problems.
The more you try to clean it, the worse it will get.
Would you modify this in addition to a VFRness harness?
I'm not a fan of the Vfrness.
Many have tried and still had problems.
Only way to completely remove the chance of failure is to solder the joints, and run a heavier gauge positive cable directly from the R&R to the battery through a heavy duty weather proof fuse.
 Wait, what?
 That orange connector is a ground junction block for the meters, lights, and ECU. Hooking it to the positive side of the battery will cause some pretty spectacular fireworks. It is easily cleaned by soaking with DeOxit, and compressed air. Like most of the low current connectors. The high current connectors are the ones that need to be hard-wired.
Your VFR and the RC45 are equipped the same orange box... the flaky ground was the cause
of my flicking F1 light 4 years ago...
For a permanent fix I removed the orange box by taking a jewelers screw
driver and carefully depress the tab on each metal connector while
tugging on the green wire with needle nose pliers... then assemble the
ground pins back onto their corresponding wire and solder...
[image: gallery_3131_51_5519.jpg]
[image: gallery_3131_51_1400.jpg]
[image: gallery_3131_51_12600.jpg]
[image: gallery_3131_51_42082.jpg]
[image: gallery_3131_51_41148.jpg]
End of thread · 8 posts recovered Wayback Machine snapshot 1 Apr 2016
