K&N Oil Filter Recall - KN-204
16 posts Started 10 Nov 2017 Last recovered post 16 Nov 2017 Wayback Machine snapshot 18 Nov 2017
About bloody time, long overdue.
"K&N has discovered that certain KN-204 and KN-204C oil filters manufactured between March 1, 2016 and September 30, 2016, can leak oil at the area where a nut (intended for use to remove the oil filter during routine oil changes) is welded to the end of the filter. If there is such a leak, oil could come into contact with the rear tire or rear brake of the motorcycle on which the filter is installed. If this were to occur, it could lead to a loss of control or a crash."
 Wouldn't touch them with a 10ft. pole! There have been numerous posts about these filters failing.
Vfr I just purchased has an oil leak somewhere. Also had a KN-204 filter.... I hate their crap and how people really think it makes their vehicles faster.
Here in Australia - no recall.
However mine gave way in the last few days - mechanic replaced filter and oil today. What a pain.
I don't understand that tiny little production run being recalled. I had a failure back in 2012. Others have had failures in other years too. And there have been several K&N failure threads long before 2016.
19 minutes ago, DriverDave
+1.  Member Olive had a catastrophic failure of one of these in 2010.   I had a friend with a 5th gen that had a K&N failure too.  Could have killed him.    Really puzzling that the design itself hasn't been re-evaluated.
I'm still surprised that folk still use them given their "popular"  failure rate.
Before I got my VFR, I used K&N filters on my Ducati.  Never heard of any failures on a Ducati.  Very active forum.
Have to say the most failures I’ve heard of have been on US based forums. Heard my first UK one earlier this year and my first OZ on one this page.  I’m on quite a few forums across the board.
FYI
The old units had the nut riveted on.  The new ones are welded which I've been told has alleviated the issue.
^^^Nope!  Mine was welded.  Pretty sure they've all been welded for many years.  In fact, I've never seen or even heard of it being riveted on until you posted that.
Mine is clearly riveted and so are the others that are affected in the recall notice. New ones are welded. I took a look at them in the shop - its an accurate statement as far as the samples I have seen.
Why in gods name would they rivet it on? it's like they are trying to find the dumbest way of doing things
Urbanengineer, 11/13/2017 at 11:31 AM
The magic of advertising, brand identification and sucker consumers (sorry guys, nothing personal, just the way it is).
Especially silly when the OEM filters cost about the same as K&N's crap, perhaps even a bit less.
Though I wonder if some shops might be using the K&Ns because of a better profit margin on them.
It’s easy money! K&N air filter even comes with a warning sticker not to throw it out when it needs replacement hah!
You notice its only model kn-204.
End of thread · 16 posts recovered Wayback Machine snapshot 18 Nov 2017
