Just finishing up the last few bits on this build, figured it was time to share here. This will be a long multi-segment post, so keep checking in till the finished pics pop up.
The (rough) design brief... CBR1000RR tail, F4i RSU fork swap, handlebar and riser conversion, round headlight, front mount radiator, custom exhaust header with low/underbelly muffler and exit, powdercoat lots of parts. Overall, the usual crisp, clean, loaded-with-details build with a P51 Mustang - airplane inspired theme.
Starting with a reasonably clean albeit slightly higher mileage '99 model:
[image: 20160827_222947_zpsy5fnuwrc.jpg]
[image: 20160829_181553_zpse4brbp0f.jpg]
[image: 20160829_184202_zpspefgulbn.jpg]
[image: 20160829_184547_zpsrzo6nrxd.jpg]
[image: 20160903_164538_zpsgg0ut3nh.jpg]
[image: 20160906_153945_zpszrliosev.jpg]
[image: 20160903_165209_zps4e6972xc.jpg]
[image: 20161102_171546_zpsulbztqck.jpg]
Coolant drained, rads off, brakes (mostly) bled out, rear axle nut cracked loose. On track for fork swap by weeks end
Washer fluid bottle makes a good drain catch for coolant streaming from the drain at the pump
[image: 20161103_170147_zpsblrvzwvm.jpg]
[image: 20161103_175507_zpsk1o4irbt.jpg]
Not much, but at least it looks a bit lighter with the side rads gone.
[image: 20161103_175540_zpsk8ctpv8l.jpg]
More disassembly.
[image: 20161105_205631_zps7bkakou8.jpg]
Removed hand controls, linked brake system, clutch slave, pair system, other misc stuff.
[image: 20161105_205756_zpslvrdvan0.jpg]
She's pretty grungy, got my work cut out for me to make it clean and shiny again.
[image: 20161105_205739_zpsf7vyvs5k.jpg]
[image: 20161105_205805_zps0kyj9ymb.jpg]
Always gets worse before it gets better...
[image: 20161105_205822_zps7lmz4cz9.jpg]
Found a broken airbox lid
[image: 20161105_210127_zps5omzwz8z.jpg]
Fitted the F4i forks and triples, and a set of brake calipers. The VFR wheel fits almost perfectly.
I did have to cut off the F4i steering lock stops to fit the lower, will make new ones later.
[image: 20161106_000243-1_zpsvqto2ptr.jpg]
[image: 20161106_000259-2_zpsxzscn8fb.jpg]
[image: 20161106_000321-1_zpsc9c3lteq.jpg]
Then I offered up the CBR tail
[image: 20161105_235453-1_zpspg0fepbh.jpg]
I'm happy with how the shapes will blend. With the right blend panels and paint, it will look factory.
[image: 20161106_000216_zpsde9gvbmc.jpg]
[image: 20161106_000231_zpshqiuiete.jpg]
