Power Commander V fix for 2000-2001 VFRs
17 posts Started 9 Feb 2020 Last recovered post 20 Mar 2020 Wayback Machine snapshot 9 Apr 2020
Dynojet now provides a patch that enables Power Commander V [PCV] to work with 2000-2001 5th gen VFRs! It's true! At least Dynojet says it's true. Dynojet is the company that manufactures Power Commander and has provided the file along with instructions for downloading it to a PCV. We haven't put it to the test yet, but are eagerly looking forward to doing so.
Thanks to VFRD member Rob916 for poking us with a stick about this topic and getting us to post this info. We also posted this information on the 'New Performance Header" thread, but thought it worth reposting here in the 5th gen forum in case it can be of use to anyone not watching the header thread.
Some may recall that a number of owners of 2000-2001 5th gen VFRs have tried Power Commander V on their motorcycles and found that with PCV, their engines ran very poorly, exhibiting rough, erratic power output and misfires. 1998-1999 VFRs seem impervious and are able to use PCV with no problems. Now, in theory at least, there is a theoretical solution.
Last week Jozef Tomasovich helped connect us with Dusty Schaller at Dynojet [Some might recall that Jozef is the dyno tech at Attack Performance where we did all the dyno testing/tuning of the new performance headers]. Dusty is the product manager of Power Commander and sent the attached file along with these instructions:
"You need to update the PCV to this datafile [the file attached below].  The only way to do this currently is with Power Core software using Dyno control.  Open Dyno control and go to Support – Send data file.
To get Power core go here - https://www.dynojet.com/downloads/power-vision-3/  Scroll down to Software"
Here is the file:
If anyone gets a chance to try this before we run it on our 2001 5 gen test bike, please post your procedure and results here as soon as possible.
Hmmm, this has been said before.
I'm hoping it is true this time.
Running PCV on my 99 VFR with only 25,000 miles on it. It only starts with the choke (idle enrichner) significantly dialed up until it warms up then I have to adjust it back down. The idle does not sound very clean either.
Previous 98 I rode only had these symptoms at around 130k miles. I attributed it to engine wear.
Curious if this patch will work on the 99 model too. Will it theoretically not have I'll effects on the 99 if I use this patch?
Bike does run strong overall. I have a Two Brothers full exhaust on it as well which may tie me into the performance header category.
6 hours ago, sfdownhill
Here is the file:
It looks like you need to hook up the PCV to a DynoJet Dyno to install the patch?  It would be nice if this is a true solution!
JZH
59 minutes ago, JZH
JZH
From the email instructions that I read, it appears that there is a software you run on your PC to install the file.
1 hour ago, JZH
Good question JZH and good observation Duc2V4. You guys prompted me to take Dusty's instructions out for a test spin.
The software is indeed intended to act as interface between a technician and a Dynojet dyno, but the program was free to download and came in a 123.88mb zip file. Power Core version 2.1.1 loaded easily onto my PC and includes four applications for operating and using a dyno for tuning. The Dyno Control app within the Power Core suite opened and under the support tab, the app was indeed ready to 'send data file', but I don't have a Power Commander V here to test the procedure.
So the software and process are available, free, and viable, but we'll need someone with a 2000-2001 5th gen that has a PCV installed to verify that the patch file actually saves the day.
2 hours ago, VFR Capt.Bob
That's a good question, Captain. I don't think I'd mess with a working PCV system like yours unless there is a guaranteed way to restore the PCV's firmware/software to its original version without the patch. If the patch screwed up your VFR's operation and your PCV couldn't be restored, you be stuck with a Dynojet brick equipped with a fuel injection harness.
Regarding the 'not very clean' idle, have you tried synching the starter valves? I have not yet done this on my 2001, and I don't know for sure whether the starter valves are related to idle - just throwing it out there.
I will definitely go the major tune and service route first. Then maybe try some different maps. May even throw down for a dyno tune custom map.
This just caught my attention.
I believe this patch was pioneered as a result of a customer of mine having his 99 tuned at a dyno shop in Seattle. We had installed an older model PC with ignition control so the header I built could be tuned properly. The shop he took it to insisted that they could not work with the older model PC2 and sold him a PC5. The bike didn't run properly with that one(as we suspected) and the shop worked with Dynojet to get it working properly.
SEBSPEED, 2/11/2020 at 9:46 AM
That's very cool, Seb. PM sent
sfdownhill, 2/9/2020 at 4:20 PM
I have the Power Core software running on my computer, but my PCV unit is not recognised by the Dyno Control app.  The C3 Tuning app (part of the Power Core suite) does recognise it, so I believe the problem is that the Dyno Control app only looks for Dyno modules, not PCVs.  So, unless I'm doing something wrong, I think we still need to work with a friendly DynoJet dyno operator and a PCV owner, to see if the patch actually works.
JZH
1 hour ago, JZH
Sounds about right.
The patch worked on my '99*. installation is easy and can be done with Windows computer.   I called Dynojet and worked with Danny Boardman Powersports Technician   You'll need: 1) PC5 to update connected to computer, motorbike off 2) The file (B16-005.02.ddat) downloaded on the computer you will use to update the PC5 3) Dynojet Power Core installed on the computer you will use to update the PC5 4) After install, start Dynojet Power Core 5) At "Power Core Application-Launcher" Select "WinPEP 8 Dyno Control" 6) At "WinPEP 8 Dyno Control" window, select the "Support" tab then "Send Data File" button 7) A pop up window will appear asking for location of "B16-005.02.ddat" '8) Select the .ddat file, press the "Open" button and start update 9) After the update, close all Power Core applications, important as you can not continue to next step if any Power Core applications are open 10) Open "Power Commander V Software" and load your PC5 with a zero map or any map of your choice 11) Go for a ride   I suggest checking starter valves.  I set mine a few weeks ago after "Wade Header" install and once home after update, I found 3 and 4 were significantly off while 1 and 2 were spot on.  Idle increased from 1,200 rpm to 1,300 rpm       * My '99 was originally a Calif bike with California ECU 38770-MBG-771 and California cams. In Oct '19 with 11.8k miles, converted to EU ECU 38770-MBG-003 and 49 state cams. I ran the '99 in this configuration with stock header and Staintune without issue. In Jan '20 I replaced the stock header with the "Wade Header", again no issue. In Feb '20 I installed PC5 (SKU 16-005) and had issues similar to SFDownhill's when he had his '01 initially Dyno'd with prototype headers at Attack. (see below) After the update, I loaded the PC5 with a zero map and went for a ride. A few hard pulls by the Richmond Shipyards convinced me all was well. I changed the zero map to the Attack map provided by sfdownhill and my VFR was transformed.   New 5th/6th/8th gen performance header now in production in USA
[image: PC5_Upgrade_05.jpg]
[image: PC5_Upgrade_06.jpg]
[image: PC5_Upgrade_07.jpg]
SEBSPEED, 2/12/2020 at 3:46 AM
You do have to wonder why they say this ("planned obsolescence, perhaps?)
I have a PC2 on my bike, and will be installing the Group buy headers later this year (along with the "20 year refurb" stuff - thermostat, hoses etc.)
I've already spoken to a local dealer here about having the PC2 tuned. He's at least willing to give it a try. I know for a fact that I can run up the old PC software on a Win10 tablet, and connect to the PC2 via USB-serial cable. It will monitor the PC2, displaying revs etc. in real time and so on. And all the other crap is accessible from the interface (ignition/fuel maps etc.)
Worst case, he straps it to a dyno with exhaust gas analyser, and uses the tablet to make "some" changes to the ignition/fuel mapping...Or is that not the case?
I always suspect that Dynojet dealers/tuners have been "warned off" providing support for the old PC2s, and wonder why that is...
Hi, I’m finding this discussion very interesting.
I purchased my yellow VFR new in 1999 in the UK and still have her.....
I also bought a PC2 around 2001 on eBay but didn’t fit it due to my Insurance company’s restrictions on perceived and undeclared “Performance improvements” and grossly increased premiums....
It has sat on a garage shelf ever since!
Chris B.
The yellow in the ROW was a '99 colour, so manufactured before the Y2k changes, which have been problematic for those of us with "final edition" 5th gen VFRs.  I've found that declared mods that are not expected to significantly increase performance (I don't think most things would do that--certainly not a re-mapping device, alone) do not affect my premiums at all.  However, I am not a 20-something single lad with a job as a market trader...
JZH
In Oz, modifications to exhaust, suspension, brakes or fuelling (including modules like Dynojet) do not affect your insurance.  I actually checked this with my  own insurer.
Obviously other countries differ.
And something I found surprising, when I transferred my insurance to my new 1050 ST it was actually cheaper.
The VFR was insured for AU$5200 + AU$2000 of riding gear and it cost me AU$320 yearly.
The new Sprint 1050ST is insured for AU$6500 + AU$2000 of riding gear and costs me AU$290 yearly.
Who would have guessed?
End of thread · 17 posts recovered Wayback Machine snapshot 9 Apr 2020
