Greetings everyone, I am new to the VFR forums and have found this site to be a tremendous resource. I hope you guys can help me troubleshoot my issue.
I wasn’t looking for a project when I came across this non-running 2001 VFR, but after research and YouTube videos, I decided to take a chance (It was the dyno pull videos - that sound is something special). It’s a low mileage bike with only 8,594 original miles! (not a typo). It still has the OEM tires, though dry-rotted and bald. Previous owner said it ran last time he rode it but does not start now, selling due to surgery and getting older. Been dropped on both sides but not crashed, will need fairing kit. He said its been sitting about a year, but judging from the amount of dirt I’d say more like 4-5 years. It was stored in a lean-to type shed with a dirt floor, basically had a roof over its head but open to the elements otherwise.
Got it home, new battery and changed all fluids except brake, fresh gas and turned the key, no green neutral light on the dash. The neutral wire and oil pressure wire were severed and there was evidence of a mouse nest. Rigged a temporary ground for neutral wire, the fuel pump primed and she turns over but no start. At this point I became aware of the vulnerabilities of the VFR harness and R/R. I inspected every single plug (including the hidden multi block grounds), and found zero corrosion or indications of heat, pleasantly surprised. Will do RR upgrades as soon as is practical but want to get it running first. Continuing on…
Pulled and tested fuel pump, 250cc @ 10sec out of main fuel line. Checked spark, weaker than I like, orange color. The left cylinder plugs were dry and the right side wet with fuel, injector voltages are little more than 12 volts each, 12.2 I think . Digging deeper: pulled fuel rail and throttle bodies, lines were clear, rail was clear, no debris or varnish. Vacuum lines still supple, no cracks or dry-rot (I know I Know, should have replaced them, I still may). Repaired the neutral and oil sensor wires, ECT wires were ok. Tested the injectors, no clicky clicky on the dry cylinders, wet ones clicked. Installed 4 new injectors (helpful hint, same part number as Honda Civic), and tried to start. The bike started and ran one time for about 2min. I was able to record some of it, see video of idle and attempted start. Hard to start, very low idle initially but slowly stabilized at 1100rpm then slowly increased to 2k rpm, then slowly decreased to under 1K rpm and died. Gave it tiny throttle while at 2k and it immediately wanted to die. It hasn’t started since and only gets the initial fire. There are no FI codes, unplugged the MAP to create a code to verify and it worked.
My intuition tells me its probably one of the vacuum lines but thought I’d check here before removing the throttle bodies a second time. Again, I really appreciate the forums here and I welcome any suggestions.
Video Not starting:
Video Running:
