I only got to ride this 94 miles before the weather ended the 2025 riding season. Good thing I got in 11,000 miles on my ST1300s. With those made ready for next year I got the VFR into the shop before it snowed too much.
Yesterday I fitted helibars.
Today I mounted the racks and bags that came the sale. Nice.
Sitting here wondering how far do I go maintenance wise.
Brake pads are new. Brake and clutch line fluid is clean, the wheels spin freely. Normally it would be complete overhaul of cylinders with new rubber.
maybe next winter.
The clutch mc boot is broken. That will get rebuild kit.
No known valve clearance checks with 54,300 miles and told probably not. I act like I am thinking about it but I will almost certainly go in there.
The night I rode I noticed that the headlight brightness did not change with rpm. Voltage was about a flat 13.1v.
Another thing, the key apparently needed some jigging to start the bike then all ok until next key on. Then the lithium ion battery was low from sitting a few weeks. Accidentally charged it for 5 minutes in lead acid mode. Ran back, changed lithium ion mode and find it only has and only achieves 2v.
Put a battery from an ST1300, fired up with no extra key wiggles. Ok.
I see it has a same style but not original R/R
I have been down this road before with my previously owned Blackbirds and VFRs.
I see a new stator, 847 R/R and battery in my future.
28 years old. Just do the coolant hoses?
Height adjuster on the Penske shock was loose. Does not inspire confidence in previous mechanic. Front brake line clamp under triple clamp not tight. Looks like I’ll be checking everything.
I need a lighter spring. Do I learn how to rebuild the shock or luxuriate by having Traxxion do it? I’ll probably have them set it up for me initially then consider doing rebuilds myself.
Still, overall the bike looks fairly well ridden and taken care of.
I am very happy to have this bike.
Time to look under the hood.
