Hi all,
I've collected almost all the parts I need to do my fork conversion, so I thought I would share my plans on here. Mine is an '04 Asphalt VFR800 with ABS; I have already pulled the main ABS fuse and rode around, and had no issues, so I don't think the de-link/de-ABS is going to be much of a problem. My goal is to improve the bike's performance to close to where it would be if it were receiving biennial updates to keep pace with the GSX-R750, which means losing weight, improving dynamics (braking and turning), and improving engine power and delivery. This modification obviously addresses the first two.
[image: post-10025-125947282008_thumb.jpg]
It started where many on here have already been, with RC51 SP1 and CBR929RR/954RR triple clamps. When I started seriously considering this conversion, I decided that I would need to have inverted forks with radial brakes. That eliminated the most common upgrade, the RC51 SP1, which automatically made the process harder. The next place to look would be at CBR1000RR forks, but they seemed too short (based on my research).
Inverted Fork Swap Data Excel 2003.xls
That opened it up to other brands, and after looking hard at the GSX-R family of forks, I finally decided on the '06-'07 Kawasaki ZX-10R (which I thought would have 743mm forks, but ended up 738mm). The Kawi forks use a 25mm axle, so I next tried to find a wheel to fit. Also, the ZX-10R uses 210mm fork spacing (the triples are 214mm), which means custom wheel spacers (and eventually, rotor spacers too...).
[image: post-10025-125947280313_thumb.jpg]
After a few dead ends, I decided to use a Ducati 748/916/996/998 wheel (since they use a 25mm axle, and the 5-spoke design matches my VFR's 8-spoke rear). Well, a couple days after buying a wheel with rotors on eBay (actually a Brembo wheel for Aprilia RSV-R's, which fits the Ducati) I found something even better: a cast magnesium Marvic Penta II for the Ducati 749/999. I jumped on it, and now I have a Brembo wheel to sell, but that's a different story...
Then I got a set of Ducati 848 rotors (which interchange with 749/999 rotors). After trolling some Kawasaki forums, it turns out the stock ZX-10R Tokico calipers were kind of weak, so I abandoned the set I had scored and instead bought a complete '04-'05 CBR1000RR braking system. I got a set of Vesrah pads from Kurveygirl and some lengthened Spiegler lines from the guys at Convertibars. The CBR calipers in conjunction with the 848 rotors resulted in needing 15mm caliper spacers, which I should have had machined but got lazy and bought from Dan Kyle.
So now, I just need to have some spacers machined (~5mm rotor spacers, which makes me a little nervous, and some axle spacers for the 999 wheel). So, if you know a good machine shop in the San Diego area, let me know. Although I will be moving to the east coast in a month, so I'm open to almost anything.
[image: post-10025-125947277896_thumb.jpg]
Parts List:
Triple Clamps - CBR929RR/954RR (I may use an RC51 SP1 upper if I have to put the clip-ons below the upper triple clamp)
Forks, axle - '06'-07 ZX-10R
Clip ons - Cycle Cat risers for Ducati Monster
Fender - Carbon fiber for ZX-6R/ZX-10R
Wheel - Marvic Penta II cast magnesium 5-spoke for Ducati 749/999
Calipers, Master Cylinder - '04-'05 CBR1000RR
Rotors - Ducati 848 320mm
Pads - Vesrah RJL for the CBR1000RR
Brake lines - Spiegler extended lines for CBR1000RR
Caliper spacers - 15mm from Dan Kyle
Custom bolts - stainless 70mm caliper bolts, 20mm rotor bolts from Pro-Bolt USA (due to caliper and rotor spacers)
Steering bearings - All Balls for Honda (CBR929RR/954RR and VFR800 use the same)
Axle spacers - (to be) custom machined; I have a couple chunks of 6Al-4V titanium sitting around...
Rotor spacers - also (to be) custom machined; I'll probably go 4.5mm thick
I also have a set of '04-'07 CBR1000RR Vortex rearsets sitting in my closet, with a 600RR rear master cylinder. I need to have new mounting plates machined to slap them on, which is also on the "to do" list...
Lacy
