hiya ,some of you may have seen my build thread http://www.vfrdiscus...ighter-project/ in which i have done a wheel swap , it may not suit all but i thought id share as a few have done the fork swap , originally i wanted to go for the car wheel option as it would look awesome but i wanted the bike to track straight and having a 6' or a 7" wheel with a fat tyre as close to the swinger as possible it wasnt going to do it , i know it may have been out by 5 or 10 mm but i wanted it straight , tried to source a 5.5" wheel and even considered machining one but $$$$ so what other options are out there , what about cb1000r , so i looked and found a front and a rear and a new back tyre to boot for $700 honda want $1800 for a new back wheel alone
so the process , more detailed in the build thread
the wheels
[image: Posted Image][br]
the cb wheel doesnt have the recesses for the disk bolts but i dont think this will bother vfr800s and the offset is perfect and its a 5.5" wheel
so i machined the tops off socket headed bolts and fitted them to the shallow recess in the hub this allowed for the wheel to sit flush to the hub
once fitted with the 180 tyre its close to the standard chain guard but has plenty of clearance to the swinger
and there ya go , nice
the front wasnt so easy , cbr 929 forks and wheel , bigger axle than the cb wheel and slightly bigger bearings
the cbr disks are bigger but the mounting and offset are the same
cb axle bearing spacer is narrower and the bearings outer dia is only 2mm smaller
so i had the centre of the hub machined out the 2mm and there is heaps of meat in there so i wasnt worried
then had the spacer tube narrowed new outer spacers made wider to make the difference up and new seals
so all that was left was to slide the axle in , do her up and stand back and admire
all up for machining , new bearings , seals was around $160
hope this helps some
the wheels
