Does anyone know this or can someone measure this?
Need this info as I'd like to know if this wheel would be an option for the 3rd gen in search for an ultimate light front wheel.
If the dimension is the same as in '08-11 CBR1000RR (138mm by my measurements) it can be fitted with simple spacers cut to correct length as the the bearings in the 600RR are the same as 3rd/4th gen. I have confirmed that the 1000RR wheel can be fitted but this requires more complex spacers as the are no mathing bearings with 20mm ID and the 1000RR uses 25mm axle.
The older models I've already ruled out as the rotors are too wide on those. So can anyone help me out here?
