Hi All,
I've been toying with the idea of a bigbore VFR800 to carry on where Honda could have gone. I've updated all the cycle parts on my Viffer & now looking toward next winters project. So to that end I've bought a few bits to check the possibilities.
First thought was CBR929 pistons @ 74mm bore verses the VFR's 72mm. That would give 825cc, the other option was the CBR954, but I thought that would be one to big & two to heavy, until I found a site by accident listing the 929 to 954 changes, one of which was the pistons are lighter than the 929's !
So I acquired a piston to test the theory & removed a standard one from my spare engine. So here are the findings;-
All pistons use 17mm wrist pins,
Deck heights & piston crown heights are the same.
As are the valve pocket dimension (but would need to check valve to pocket clearances).
VFR Std Piston 72mm = 238grams (inc wrist pin)
CBR929 Piston 74mm = 246grams (inc wrist pin)
CBR954 Piston 75mm = 227grams (inc wrist pin)
So the 954 piston is lighter than both the standard VFR & 929 one, this means the rod loads would NOT exceed standard specs & the rev range could be maintained :) Deck heights & piston crown heights are the same, as are the valve pocket dimension, but would need to check valve to pocket clearances.
The next consideration is cylinder wall strength & compression ratios. The cylinders have 8mm walls & Honda supplies .25 & .5mm oversize pistons for the VFR, so max overbore leaves 7.75mm walls.
929 pistons takes that to 7mm walls & is probably OK & gives 12.2/1 compression ratio, which would restore the dynamic compression ratio to the same as standard with my cams (std=10.86, my cams/929 bore=10.91). Which is perfect for standard unleaded (UK=95RON).
954 pistons takes that to 6.5mm walls & may be OK & gives 12.5/1 compression ratio, which would increase the dynamic compression ratio to 11.16. Which is too much for standard unleaded (UK=95RON) & maybe a bit much for Super unleaded (UK=97RON).
Options ?
1. Risk the wall thickness being sufficient. CBR's have thinner walls between the cylinders & use the same MMC liners !
2. Use containment rings to reinforce the cylinders, only need to reinforce the top 15mm to stop flex at peak pressure, which can cause D-chunk failure of the liner.
3. Machine the 954 pistons to lower the compression ratio, to acceptable levels & match the VFR valve spacing.
4. Have made or modify standard head gasket to fit pistons.
So what would this give us ? Well VFR750's taken to 837cc have shown 133rwhp & they used heavier JE pistons ! So a VFR848 should pump out around 135-140rwhp :) I'd expect around 62-64 ft/lbs torque with the additional compression etc.
Worth the effort ? Well if you do the spannering yourself & use second-hand pistons (they are silly expensive new) Then you should be able to get it all done for less than 1000UKpds (<$1500).
Your views as always are appreciated :)
[image: 7j2b.jpg]
[image: mab8.jpg]
[image: gt8f.jpg]
[image: d92p.jpg]
[image: es7m.jpg]
[image: q9od.jpg]
