If You Have More Than 50,000 Miles Or 80,000 Km On Your Vfr1200
38 posts Started 10 Nov 2014 Last recovered post 30 Apr 2017 Wayback Machine snapshot 5 Jul 2017
Please post up with any mechanical failures you have personally experienced.
My goal is to gather this data and from time to time I'll summarize it on a spreadsheet which I'll publish here and we can start to see what weaknesses we should be on the lookout for, and possibly even do some preemptive parts replacements to avoid getting stranded in the middle of nowhere.
Please DO include replacing brake pads, clutch plates, etc, not that's really a "failure" but it is something it would be good to have replacement data on.
Please post.
Model Year
DCT or standard
Mileage at time of failure
Nature of failure (or "worn out" item)
Bonus question: What kind of oil have you been using and how often do you replace it?
It would be nice if people would not go off into discussions about all this in this thread, please start a new one.
I'd like this to be a pure data thread, and we can all interpret and debate in other threads. (I know, fat chance on that request!!)
thanks
2010 VFR1200F with 54,000 miles. No issues at all. Check valves @16,000 mile intervals and so far only one exhaust has been out. Brake pads @ 25,000 miles. Oil is Mobil 1 full synthetic, 10w30 every 4,000 miles. It's a great motorcycle.
2010 - standard - 81000 km - No failure
Never checked the valves
Never changed the spark plugs
Never changed the rear brake pads
Changed the front brake pads every 25000 km (average) - Always original except the last one, Lucas
Changed air filter every 24000 km
Changed final transmission oil every 12000 km (together with engine oil)
Engine Oil : Procycle SAE 5W40 API SM Jaso MA2 - Full synthetic (from Louis, Germany)
Transmission Oil : Procycle Gear Oil SAE 75W140 API 5GL - Full synthetic (from Louis, Germany)
here's my entire service record from day one....if you care to indulge....no serious failures...a few issues, but nothing major....headlight hi/low relay was replaced because it was slow switching between beams and then headlight went out entirely ...thought that fixed it but it acted up again recently....otherwise just maintenance...oil every 3000 miles...bel ray EXP ....tires have been lasting about 8000 miles ....valves were ok at 17,500 mi and plugs were like new....love this bike
HONDA VFR SERVICE RECORD - Copy.doc
Edited November 10, 2014 by lshark
Thanks for posting your record. Hope my VFR will be as dependable.
31K Miles and ZERO issues. Didn't bother with a valve check but I've had all of the other services done by the book.
Mobil 1 since it's first oil change. She's lived her life in a garage with lots of washing and waxing. In March, I will have had her 4 years and I have loved every minute of it. Still looks brand new.
Unfortunately, this summer was not kind to me with available riding time. Maybe 1500 miles MAX....(I should be shot)
On the bright side, my tires, brakes, and all fluids are ready to go for Spring.
Edited November 12, 2014 by Headhunter
VFR1200F
2010
50870km at the moment, it had 2 problems.
@48000km
1)Saddle started to show weak spots and teared holes in it near the tank, Honda replaced it under warranty (very good!)
2)Rear suspension needed to be replaced, the knob got stuck and couldn't turned anymore, I had to pay 33%.
My dealer told me all Honda's have this problem at about 50000km and it's a construction failure.
I'm not so happy Honda charged me for the last one, as they have a v2 rear suspension made but mine is still V1, so it could happen again at 100km.
Other then that, no problems.....I did do a Guhl flash as it ran rubbish on the standard ECU programming.
I know it's not 80000km, but problems start at about 50000 according to my dealer.
Well, I have some data from a few people. Thanks to those who posted. I'll update this next time I have 3 or more new posts from people with at least 30k Miles.
[image: Untitled.jpg]
Edited November 23, 2014 by kurtfriedrich
kurtfriedrich - you are my kind of nerd! I use Excel to track all the time too.
Hi, I bought a 2010 last fall with only 26000km on it and had a number 2 connecting rod bearing failure. The PO had all service done at the dealer at about 5000km intervals. Bike was out of warranty, so he sold it. I am in the process of repairing it now.
holleman14
That's not nice to hear.
holleman14
Probably its related to Honda recall regarding the aluminium chips residue.
satariel666
holleman14
I think that was a UK only situation but, you're right, can't rule out a relationship.
1998 VFR. Countershaft 6th gear dog failure at 74K miles. Bike had shifting issues since it was purchased with 18K. Replaced countershaft 3rd, and 6th gears. Everything else looked like new inside. Shifts like butter now.
1994 VFR bought with 125K miles. Now at 130K miles. No smoke, leaks, or bearing noises. Shifts like butter. Runs like a scalded dog.
I know you asked for at least 50,000 miles but I have one that may seem to be a problem. I have had the seat tear on two seats now in the same spot towards the front on the left hand side. The first one was replaced under warranty and the second seat is going to be replaced too with the new updated seat from a 2012. My bike is a 2010 VFR1200F 12,000 miles with no other issues that would be consider a failure. But I did have a leaking front fork seal.
Also, had the dreaded crack on the rear silver cowling that covers the brake reservoir, that too was replaced under warranty.
MBrane
Don't think these are 1200s, I only tracking the 1200s.
thanks!
I also have the torn seat cover on the front left corner where it meets the tank. That happened in August 2014 at about 18,000 km on my 2010 VFR, which I bought new in March 2011. I figured that as it was well out of its one year warranty that I would have to pay for a new (or aftermarket) seat. Maybe I'll see if a local dealer can replace it under warranty. Doesn't hurt to ask.
BrandX
I would have them talk to the Honda rep and let him know that this is an ongoing problem. Mine was replaced twice under their good faith money. The dealer can explain that to you.
Anyway good luck and let me know if you need my dealer info.
Updated with the last few items:
[image: Untitled1.jpg]
2010 VFR1200 DCT Purchased 5-28-2010
Current Mileage 160,050 Kilometers or 100,000 miles
[image: post-20375-0-49670600-1427017455.jpg]
[image: post-20375-0-64354900-1427017477.jpg]
1.Major failure: U joint snapped in the middle of trip at 94,000KM. I abused it somewhat with hard launching off line and hard acceleration. $2,000 for replacement.
2.Spark plugs changed at 94,000KM, Denso (factory plugs) looked good, changed to NGK. Will probably change them out at 200,000KM.
3. Changed air filter once at 94,000 KM, usually just used compress air to clean and put back into use service after inspection of the condition of the filter. Check filter every 6 months.
4. Checked valves at 94,000KM Exhaust valves adjusted. Next check at 200K.
5. Brake pad changed 5 times, Honda pads.
6. Oil every 7,000-7,500KM Use Korean motorcycle brand Called SK motorcycle oil 10w-40 cost $3.50 liter compared to Mobil ONE $28 a liter. both oil JASO Ma approved.
7. Shaft oil every 15,000KM use Mobil 75-90 or GS 75w-85, GS is a Korea brand is part of LG TV company.
8. Left brake rotor warped twice (side with abs ring) warped badly at 80,000KM & 103,000KM, probably due to stuck piston or dirty bobbin/button.
9. Changed seat to Corbin, it seems the foam was too thin from Honda seat or it wore out over time. Corbin made a big difference in comfort.
10. Changed coolant twice, Prestone 50/50 premix.
It's been a great bike, other than the U-joint failure and warped rotors which I take responsibility for.
Edited March 22, 2015 by Dae
WOW!
DCT with 160k km's. Gotta be a new record.
Updating my data.
km 83922 - changed spark plugs with original ones (NGK IMR9E-9HES)
The old spark plugs were in good condition, I think that 100k km can be made without problems.
Actually by bike has 85384 km.
For Dae:
You have adjusted the exhaust valves at 94k km: the gap was bigger or lower than the required one?
I'm not mechanically competent enough to do valve adjustment, local Honda dealer here in Korea performed the service. Basic maintenance I do myself.
ilprofessore My original spark plugs were Denso, I guess Honda uses both NGK & Denso from factory. Edited March 22, 2015 by Dae
satariel666
I guess you don't like to do chain adjustment, from the motorcycle you own. I do really love the low maintenance of shaft driven machines.
Both Denso and NGK hq's are separated only by 32km's. Honda is 100km to the east. In exact the same place, Hammamatsu you will find Suzuki as well.
35km's east from Honda you will find Yamaha Motor Company.
Only Kawasaki is 250km's apart - west.
Small land, vast industry. Everything on hand.
Dae
satariel666
I love drive shafts - however my vmx1200 is converted to belt drive using the vfr 800 swingarm...not finished sadly.
Going to sell the vmx1700 - very unpractical motorcycle since I bought the vfr 1200.
Chains are dirty, expensive, noisy and requires a lot of maintenance. They come with a very good efficiency and easy to change ratios tho.
Also, when they snap and they tend to snap, you will end with a fewer pats and in extreme cases with a fewer limbs :D
Edited March 22, 2015 by satariel666
Dae
<snip>
Damn dude! You're my new hero!
satariel666
WOW!
Even more impressive given he's from Korea.
Hey Swimmer you like to live dangerous like me (Fuelly) I filled 18 + liters or 4.8 gallons several times. I have a feeling were going to push our bikes to a gas station or calling for help.
Bought my bike at 8,500 miles in May 2014, current mileage is 15,466 and performed the following:
  • front wheel @ 9,374
  • engine oil & filter @ 9,386
  • front brake pads @ 9,660
  • final drive oil @ 9,862
  • rear wheel (massive puncture) @ 10,299
  • front right brake disc (left disc lock on) @ 11,448
  • installed k&n air filter @ 14,700
Kudos to Dae with 160,000km's. Helps set my mind at peace when I posted a question in the forum of how many miles will the engine last.
I've booked my bike in for a full service in 2-3 weeks time. First time I will service a bike in the UK. They said it could cost up to £700, which seems quite a bit, but he did mention it could include brake pads and air filters. Anyone done a full service in the UK and have a better idea how much it would cost?
valve adjustment takes a few hours
Dae
Have you measured engine compression?
arturelagin
Dae
Does lofting the front wheel through the 1st 3 gears count as a compression test
arturelagin
Dae
No I have not done a compression test, currently at 186,000 Kilometers. This past few months I have been busy and rode less than 1,000 Kilometers. I will replace the spark plugs this winter which will be the 2nd time.
Anyone have any updated high mileage VFR1200's to report?
I'm now at 119218 km and the only issue is a warped front disc, due to poor original material.
Now I have installed 2 discs made by Braking, Italian brand well known. It happened at 105000 km.
Changed the shaft as all the others V4-1200 and stop, nothing else.
Change also the battery, after 5 years. Installed the same Yuasa YTZ14S.
Still not made the valve adjustement.
Haven't had any issues with my 2010.  I'm just over 100,000km.
Looking at used VFR 1200.
Is there a current version of the hi-mileage issues spreadsheet available?  where? Not seeing a link here.
Thanks to all who are contributing to this  great thread and the its creator.
My email: GoVFR1@gmail.com
GoVFR
Ride Safe
Proud Owner of 4 5th Gens
4 hours ago, GOVFR
GoVFR
Ride Safe
In all honesty, there are no consistent issues with this bike.  Knowing these bikes very well I'd be hard pressed to come up with any trending issue.
I'm at 42k miles and had my first failure last week.  A $3 rubber grommet that helps hold a piece of fairing on split.
Only thing to check is make sure the U-JOINT recall was performed.
End of thread · 38 posts recovered Wayback Machine snapshot 5 Jul 2017
