... then how will it affect the running of the bike (given that the sensors previously attached to the Catalytic convertor will now not be attached to anything)?
The cat does 2 things, 1. it changes some burnt gas hydrocarbons to CO2, this being its primary function. 2. restricts exhaust exit velocity, this is a parasitic loss, the design of the cat usually reduces this as much as possible, but it still obstructs gass flow.
If you add the Delkevic system & I assume it was tuned for no O2 sensors, the you don't have to worry about the bike running lean, as without the O2 sensors the ECU defaults to a richer map, so all good there. You only need one of the O2 sensor circuits to have a resistor fitted to turn the Fi light out, or buy a Powercommander O2 eliminator, which just plugs in.
You should get a better mid range, a nicer noise & about 5hp increase in peak output. Disable the pair system & do the flapper mod then fit a powercommander & have it mapped & your bike will feel much fitter & should have a much reduced snatch from on/off throttle opening.
The gain from removing the convertor is not great comparing with the fact that you, and your passanger mostly, will get choked with the exhaust gases when stopped or going very slow on traffic. Due to an accident I have replaced my headers with one without catalytic convertor but I intend to put one back.
Cheers!
How ever did we survive riding VFRs before 2000 when they added the cat? I think you are overstating the fume situation just a tad...
My intention was not to make it seem that the riding is impossible but the well being on a cat exhaust is better. The difference can be observed while standing behind a car with and one without cat (running on gasoline). Not to mention that, when I am at red lights, the nearby drivers are cursing me or the bike for the fumes. On a track and outside city it may not make a difference though... except if you are stopped by a in traffic mobile laboratory control - usually they do random checks on the vehicle safety and pollution abiding rules :)
Bizarre theory you've created there... Personally, I find the noticeable egg-smell associated with catalyst-equipped petrol engines much more noxious than that associated with older gasoline-powered internal-combustion engines. But then again, I have a very planet-unfriendly attraction to the unmistakably intoxicating aroma of a two-stroke burning Castrol R...
I've heard that adding just a little Castrol R to your VFR's tank offers that old race-bike scent to the exhaust. Don't add too much - you don't want too lean a mixture :tongue:
I've noticed an unwelcome smell when idling in traffic and my 2001 fifth has oem engine and exhaust. I feely a little guilty for those nearby. But I'm a tree hugger from way back.
A former fifth came with aftermarket exhause and a Power Commander. Fuel mileage improved by ~10% when I removed them. However the off-idle snatch was back. It was nice how smooth all across the rpm spectrum the throttle was with the PC.
[image: Castrol_R.jpg]
And I just love the smell of napalm in the morning.
End of thread · 13 posts recoveredWayback Machine snapshot 11 Aug 2025
