Modern chains don't need anything penetrating the o-rings, just the grime on the chain surface (think degreaser). They prefer to run clean and they're sealed from the factory and you want them to stay that way.
I've used WD-40 or PB Blaster for many years with superb results both in wear and lifetime. I've recently used Maxima cleaner and lube just because my friends' chains looked more shiny than mine...but no variation in results, just cost of cleaners.
The street bikes seem to get to a point where they're wearing unevenly at end of life. The track bikes start to throw rollers.
A year ago or so, on VFRD BLS recommended Motul Paste, been meaning to try it--doesn't fling.
But more importantly, just keep the chain CLEAN, and lube sparingly every ~500 miles --just so the metal-to-metal, roller-to-sprocket, has a little film.
bmart you are 100% correct IMO. The O or X rings don't need lube because they are sealed.
Ari Henning has several great videos on chain maintenance and lubing. Keep it clean, lube sparingly, and you get 20,000 miles from a chain.
I like the ProHonda HP chain lube, been using for years. Has Teflon and Moly, dries with no sling, keeps the chain clean. Wouldnt mind trying the Motul Paste.... In general, hate chain waxes, it just attracts dirt to stick to the chain, and is a goey mess.
Maxima Chain Wax, sparingly. Dust is the enemy down here in the SouthWest. I apply the chain wax after a ride and let it dry. Very little fling, runs clean, attracts very little dust.
For me, S100 synthetic chain lube (since it came out in the 80ties). Unfortunately, only available in Europe and cannot purchase in the US. As I am on the last drops, I will try Honda gear oil after watching Ryan F9 YouTube on chain lube.
Hawke Oiler and 140/70 gear lube. Changed the last chain with 25,000 miles on it. It probably had another few thousand miles left in it, but I wanted to
try the 520 conversion. Running the DID 520 chain, 17 tooth countershaft, and 45 rear sprocket. Actually feels pretty good.
Tried chain wax years ago on one bike or another, and had lousy results, but that was a long time ago. The formula has prolly been changed for the better.
Your eyes are fine! I was wondering any anyone noticed. 🙂
One of the track bikes lost the locking washer and the nut spun off in the final turn at VIR South this year. Never seen that happen before. I torque everything!
I used to run an '05 R6 at the track (I see your sig shows an '03). Came in after my last session of the day, noticed the front sprocket nut and washer were gone. Fortunately it was my last session. Looked into this and found that it was not unheard of for this gen of R6 (I also torque everything but had recently acquired the bike and did not check this sprocket, lesson learned :biggrin: ). Installed new nut and tabbed washer then torqued, added vibratite and safety wire prior to next outing. Apologies for the hijack.
Chain wax on my ZRX. Basic lube seemed to leave tight links after 200 miles. Decent spray-on wax is way more than that, I do it when I think of it instead of when it gets dry.
Honda recommends 75W-90 or 140 gear lube every 500 miles. Works well and I have gone over 500 miles. Apply, wipe clean and expect some "fly off". Clean chains is better than over lubed chains.
I recommend Motul Chain Paste... squeeze the white grease from the
tube and load the brush... Hold the loaded brush to the inside of the
chain rollers to transfer the white grease... After a couple of spins
of the chain it's lubed like from the Factory... Motul Chain Paste
clings with no flings...
Which is for resisting rust during storage and shipping. Most remove all of that crap before using it. This is a product I don't understand unless one is planning to store the bike for some period.
Cool beans. I've lived here since 2001, and lived up in St. Joe before that.
On a different subject, we've been thinking of heading south next winter for a little snowbirding. Any decent RV parks near? And more importantly, good
motorcyling roads? We stayed near Angelfire some years back and liked the area, but thinking a warmer area for the winter.
There's a big RV park on the west side, bound to be others. (Just not something on my radar) Eastern NM is high grasslands, roads are purty straight. The 'quadrant' west of I-25, north of I-40 is loaded with great twisties! South of I-40 and West of I-25 is good close to the mountainous areas. The Rockies fizzle out that far south.
North will always be cooler, partly because of latitude, but more because of elevation. Albuquerque is a mile high, the Sandia Mountains on the east side of town peak at 10,400'. (The Crest Road going up the east side of the Sandias is a local favorite.) Temps here are a happy medium between cold up north and HOT further south.
Come on down!!
End of thread · 36 posts recoveredWayback Machine snapshot 28 Jan 2022
