The way I have changed my mind about what I�m doing with my VTEC has been a saga in itself, a while back some might remember my bike with a RC51 front end. Well that was removed & sold off due to my intent to sell off my VTEC. Mr Honda hasn�t done there later model customers any favors by discounting the VFR to a point you would be silly to by one secondhand. I do like my VTEC (except for the VTEC valves for service but not what they do) so because I didn�t feel the need to give it away I decided to tinker with it instead AGAIN.
I just happened to have a 2005 R1 front end that I had started to gather parts for to install on my VFR750 (thats now has a F4I front end but is being sold). Now with what I had learnt from my RC51 install I knew the geometry I needed to setup the R1 forks & this is where I changed a few things & found out some things which you do when you can�t find anybody that has done same thing. I used a lower triple clamp from a CBR929/954 because there easier to obtain & if you do need in a hurry new due to mishap there $390AU new from Honda where the SP1 is a mind blowing $690AU. I then matched this with the normal CBR929/954 upper triple.
This is where I made a mistake because I�m using Convertibars which mount under top triple clamp because R1 forks are allot shorter than RC51 & I knew there wouldn�t be enough fork to mount clipons above top triple. Well due to fork height I new works from RC51 install I couldn�t slide forks up through triple claps far enough due to Convertibar clamp fouled on fork leg where it starts to tapper thicker. I was able to solve this problem by using the SP1 upper triple clamp which is flat not gullwing & allowed for forks to move up to required length.
Now because I can & bike was off the road I decided full service was needed due to 45000kms on the dial so valve inspection (this is a story in itself but the things I found & the time it took make me laugh when I read complaints about bills, this job is as bad as changing plugs on a V12 Jag). I also took the time out to do some housekeeping so just for the record bellow is list.
Pair valve complete removal (was just blocked off before)
Valves shims 5x VTEC, 3x NORM
Balance starter valves (I did this not that long ago with a borrowed set of gauges which I think were out because I bought my own set of quality ones & starter valves were way out & for the record bike was set to 1200rpm when I started & increased to 3000rpm when finished so had to back off idle big time)
New plugs
R1 front end install
Delink brakes, braided lines front/rear
Fit Motad catless headers
Paint wheels
Paint duct tail (hard to tell 2nd pic, top is black with VFR1 stickers under clear coat)
Fit billet fuel cap, oil cap, foot pegs
With everything I have removed I would est I have saved 10-15kgs weight off the bike but will go to weigh bridge to find out very soon as bike is ready to rock after 2 months mainly waiting for parts. Only thing left to do is dyno remap & I'll be a happy camper.
As far as handling I can't say anything except :thumbsup: better than the RC51 front you bet it is & for the performance the bike now has with all above work & Motard headers which removed the biggest problem a VTEC has. My mate on his Blackbird calls me a bastard when we ride because I just pull away under anything bellow 160kph. He even said I have been leaving faint black lines just on straight line acceleration & can change line mid corner like the thing is on rails & he has my old RC51 front on his Blackbird. Do you think I'm happy well lets just say I don't smile as much having sex as riding this bike at the moment (wife slapped me when I told her she needed an update but I was brave & didn't cry)
Enjoy :thumbsup:
wow thats a great looking bike.
Awesome mods.
Im not a fan of the tank pads and corbin seat.
but still looks great.
Now I remember why I used the 2000 R1 forks, same length as VFR to the triple clamp. No worries on where to put the bars, etc. I hope you upped the spring rate a little.
Another vote for the forks from the tuning fork people. :thumbsup:
Nice job, I guess the blue wheels will grow on us, maybe?
Larry
VFRrider
Four barrel shotgun at the rear, and bitchin blue wheels. :beer:
Tank pad & corbin are for touring, standard seat solo cowl has also been resprayed black.
The R1 forks are specials as I do work for a suspension tuner (he does the valving etc, I strip out the shocks forks etc when he needs a hand) the valving is nothing like standard R1 valving & has been specifically designed for road use as I'm the test monkey.
I'm a blue freak sorry all my cars are blue, well even my new tool box that was my xmas gift to myself.
Looks and sounds great Roy, nice upgrades :thumbsup:
thanks :thumbsup:
things couldn't get better at the moment as my VFRD shirts & sticker just turned up in the mail as well.
VERY nice. love the blue. wish i had the talent to do this to mine.
Nice. And nice to know such things can be done. I'm not planning to do this myself, but for folks who want the VFR to ride more like a supersport, this is a good (but not easy) option.
Great work there!
Care to expand on the comparison between the R1 and RC front ends? I have the RC on my '99 currently, would appreciate feedback on the differences.
Bike looks great, blue color, wheels and all. :thumbsup:
Very nice work Roy, I wish I had your mechanical skills.
Given your work for a suspension tuner, what would you recommend to improve the standard front forks on a fifth gen?
Now put a Ducati final drive in the rear swingarm :warranty:
#vfrcapn I will try, the R1 forks can be upgraded internally buy someone that knows there stuff better than most to a point you can get 60 compression settings if you wanted (me thats just way to many but the point is you can) the RC51 fork compression is controlled by the bolt on part on front of fork which means the oil has to travel in a U configuration which does slow response time. So what tends to happen is you find a good compression setting on the RC51 fork that works well but go 1 click up it suddenly feels to hard or 1 click down it feels to soft. The RC51 don't get me wrong is a bloody good simple design fork but it's not cutting edge & with suspension response time for compression & rebound is everything. Now when a suspension tuner (I'm not one I just help out) starts playing with the RC51 forks they have to make a compromise between better compression or better rebound because the design of the fork doesn't lend to valving them both to be great (thats my understanding of what he has told me). Both the RC51 forks & R1 forks have .9 springs.
Now when test riding both I found on the RC51 forks I needed to get my settings spot on to get the best out of them & was always just adding 1 click up/down when the road surface changed allot (like smooth hot mix to bumpy) but not for just general cruising, mainly for spirited riding which is about all I do (my RC51 forks also had valving modifications). The R1 forks perform better over a wider range of settings but I'm still playing with them but already my riding buddy has said my corner entry etc is way faster than before but it doesn't feel any faster. The main thing I have noticed is change of direction mid corner leaned over is pin point & can catch you out with how fast it does it. Example 25kph corner I came in hot, so hot the guy in front that I thought I gave lots of room was about to be part of my front wheel & I was close to #full lean angle. I was able to cut off corner & go the outside (there was room no cars & this guy is my main ride buddy).
Brakes well the RC51 are good but radial are better, hope above sort of made sense.
#Goanna to get the best out of any forks you have to have correct springs for your weight & valving to suit those springs, to many people do springs but forget the valving needs changing to suit, it's all about flow rates. The VFR forks for an extremely simple design are good but they tend to wear out the internal bush the rod slides through which then lets oil leak past the valving (the main rod that looks like bright steel). The standard forks are better setup a little stiffer than normal in the valving as there is no adjustment on the fly & when you start pushing them hard you need that.
#SAFE-T I wish :rolleyes:
NOTE: I only know what I like from suspension so my comments are based on that & as we are all individuals others may like things much differently, I also know nothing about the modifications to all the valving as thats my friends lot & he don't share his trade secrets with anyone or he would be out of a job.
Beautiful bike!
Absolutely fantastic sir!!!! :beer:
Very cool. That seat looks comfy as he!!, too.
Looks great, well done :thumbsup:
Very impressive work there Roy. The bike looks great. I've always harbored latent desires to do something like this and always talk myself out of it. (Almost certainly will do so again :rolleyes: ) Regardless, if you don't mind expanding a little, how did you set up the front wheel? I'm assuming you used an R1 unit, did you encounter any issues with spacing and the like and what did it take to get that sorted?
thanks.
Nicely done, looks great. I love blue too! :thumbsup:
thanks.
I wanna know too! :warranty:
The bike looks excellent Roy! I like it a lot! How much of Ohlin's technology do you think was incorporated into Yamaha's parts while Yamaha owned them? When you open the forks, are there any similarities with the Ohlins R&T forks?
thanks.
I will post up exactly the parts I used & what I did soon, but the main problem was rotor spacing on the R1 wheel because the R1 rotors are dead flat no off set at all & they locate on wheel sort of 2 ways. 1st is the small tabs on wheel & the 2nd is the rotor bolts are a thread dowel configuration but once you space the rotors out the required distance for the difference CBR triple clamps are to R1 triple clamps (2mm spacer between wheel & rotor) the R1 wheel tabs can't be used & the standard R1 bolts wont locate into wheel on the dowel part of bolts.
Ohlin's technology isn't specific to Ohlins as they all copy each other in some way because there are only so many ways to build forks that work, so it's hard to say if there is a direct relation ship but I'm sure there is as far as flow rates & what they already new works. You would be suprized how many times even Ohlins gets it wrong & just like any other fork/shock can be improved on by someone with the skill & time to do there own R&D. Everything can be improved to suit an individuals taste so just because it's a Ohlins/Penske/Wilbers/WP/etc doesn't mean there the bees knees, there just a upgrade out of the box for a factory installed cost effective suspension.
My CBR1000RR track bike forks (rebuilt as well) are just as good as the R1 units I have on the VFR but there not standard & have completely different Showa valving installed from stock so you can make anything work well you just have to know what your doing & I'm lucky my friend does as he seems to spend more time testing than making money. Even the latest & greatest Ohlins rear shock which costs a packet can be improved upon as he is testing one at the moment on a 07 R1 which he is also playing with (who gets a brand new $2500AU shock & pulls it apart almost straight away it's madness to me) & if you rode the bike with that shock out of the box to how it rides after he tinkered with it you wouldn't think it was the same shock. He wants to start his own line of valving for sports bikes that is aimed mainly for road use & my R1 forks have a prototype in them but I have no clue what the difference is because thats his science & he spends days calculating & playing with all these little round things that I have trouble even seeing.
What is forgotten about suspension even the good stuff like Ohlins is everything is machined with a tolerance +/- whatever so no 2 parts put together wil be exactly the same & as flow rates through valving are the main thing that keep your tyre firmly planted on the road you can have identical bikes with identical suspension & same rider & he will notice a difference in them both. Motogp at the cutting edge is a perfect example of this with each rider having 2 bikes that they will be setup the exact same but if rider crashes his prirary bike they will always say the 2nd bike felt different.
Missed this due to moving house at the time (although I knew you'd gotten it all together), what can I say, another excellent job!
I love the blue on blue combo and the blue front wheel really sets off the hardware. Normally it's lost in the black front wheel.
Good to hear it rides so well too :thumbsup:
Some questions, of course.
I take it you still have the Convertibars on it?
Are 929 bars an option with the SP1 top triple?
With the SP1 top triple (and the forks correspondingly raised), have you got the same front ride height as with the SP1 forks?
again you have outdone yourself the bike looks splendid !!!!!!!!!!!! your red twin in chicago salutes you :thumbsup:
Yes I used Convertibars, they did cause a small problem with ride height I wanted as the clamp fouled on fork as they start to tapper out to a larger dia. That was with original 954 top triple, which is reason I changed to the SP1 top triple which allowed forks with Convertibar clamp to slide up to height I required.
I have same ride height I used with SP1 setup with 5mm of fork showing above SP1 top triple, 954 bars I think would be to low & if you used 954 top triple you still would only have about 20mm of fork to mount clipons above top triple so with R1 forks you need to mount clipons bellow top triple & use a SP1 top triple due to problem I ran into with fork tapper (this depends on thickness of clipon clamp of course).
Nice! Another mod to add to the list. Gah.
Wow! Nice job. Hearing you talk about the handling of the R1 front end gets me thinking about my bike. Very cool.
Although, to call it a VFR1, you need to get my adapter pipe and run a Yoshimura R1 exhaust. That way, you have both ends covered.
[image: Posted Image] :thumbsup:
Nice Mods...
Any feedback on the Motad header?
regards,
[image: View Post]bayarearider, on Feb 20 2008, 11:42 AM, said:
Nice Mods...
regards,
There's a group buy stirring up for the headers purchase. Should would like some feedback from you on fitment, loundness, etc.
regards.
I cant comment on ease of fitting, but after following Roy and Kirby for a few days I can say the headers look very good, and sound great. Kirby's bike with Staintunes sounds louder than Roys with the Lasers, but not by much. Roys sounds more refined, not so raw and raspy.
...good reading Roy. Any issues with the local authorities not running a cat ? Great toolbox btw, you would be happy with the weekend results...
Nice Mods...
regards,
regards.
Sorry have been slack lately with my posting.
The Motard headers fit was perfect & for me to say that being a X fitter is for real. I have fitted 2x sets & each set bolted up without me having to use any force what so ever to bend something to line up or fit.
The sound is great not to over the top & not that much louder than aftermarket cans but with more note & crackle. The effect on my bike was very noticeable in power delivery because when you open the throttle there is power with no hesitation at all until red line & on/off throttle there is no jumpy feeling you tend to get every now & then. I don't think they would be much different from 98 headers with the main advantage being no CAT.
They have the holes for the 02 sensors & bkt for the center stand so they really are just bolt up & go, the only thing I didn't like that much was the finish which is smooth but just a painted finish over the ST/ST. If you go to Motard site you will still see pic of nice polished finish with a small note they now come painted grey which when I asked why the change was informed they got to many complaints about the headers pitting due to polished finish. I was told since they started just spraying them with paint they haven't had a complaint but I wish you could choose as I don't mind cleaning my bike & think the UK guys just lazy.
I will be having a new map on dyno done sometime in March so will post results when done as for the powers to be in AUS they think a cat has four legs with fur & wouldn't know if not installed.
Quote
No salt on Aussie roads in winter, Roy!
Well get your act together and post away, there's an AC that's been given approval to fix, tho haggling over price, and then I need to make a visit to the OBH
[image: View Post]The Phantom, on Feb 27 2008, 11:53 AM, said:
Quote
Yes I know but they don't give you the option for polished & there is noway in Hell I'm going to polish them so grey it is, I was thinking about getting them coated but as there st/st & won't rust plus the cost factor I decided against it (All my spare $$ goes on tyres & track time for the CBR1000RR).
When they stop haggling give me a call. Will talk about your bike when the other 750 leaves in the next week or so (the shock I did have for it I sent back due to marks on shaft, but it seems to now be lost in the post ffs)
http://img110.imageshack.us/img110/9250/vfr1008og7.jpg
Hey rock on brother! Blue oval all the way - love that toolbox mate it must have cost a fortune. I sure hope you own the accompanying BF or BA series FPV, XR8, or XR6 turbo as well! Personally I have a BFII XR6T which is just the ducks guts.
I only have the BF XR6 which is my work transport & track bike transport.
http://img518.imageshack.us/img518/7513/picturehn9.jpg
http://img518.imageshack.us/img518/7513/picturehn9.eeffb3881f.jpg
You lucky bums down under get all the cool cars...I wish they had the balls to bring that to the US. Or maybe it's time to migrate south....
Well, we did get the GTO... (was a Holden to start!)
Cool ride though, funny how that would be a "custom" here. If they made a Subaru Baja that looked less like a wagon and more like a truck(or just less like a wagon) I'd probably buy one. I'll stick to the Silverado for now though! Chevy Power!! :goofy:
You're getting the Holden ute soon (as a Pontiac) -
http://www.themotorreport.com.au/2888/pont...and-sportwagon/
Here's what the hottest version sold in Oz looks like... Mods, note motorcycle content! :D
http://www.drivearabia.com/news/wp-content/uploads/2007/10/hsv-maloo-1.jpg
And is this the next GTO?
http://cache.jalopnik.com/assets/images/gallery/12/2008/02/medium_2299293000_faa7919006_o.jpg
Looks cool, but I need something that can still go in the woods to haul firewood...
http://image.carshowroom.autotrader.com.au/jato/photo400/AUS/FORD/FALCON/2007/2CP%20RTV.JPG
:fing02: :fing02: :fing02:
Preferably not made by Ford? :unsure: No offense Roy...
Also, is there an "extended cab" version?
Here's the gas pig I'm driving now:
http://i8.photobucket.com/albums/a49/SEBSPEED2003/PICT0065.jpg
GM holden make an extended cab Ute.
Will look for a piccy.
you can even get a souped up version, 300kw+ V8.
Gotta be quick before the mods get here AB! :unsure:
http://au.carnewstoday.com/car-news/images/thumbs/lrg_article_198-img_0.jpg
Looks cool, will a bike fit in the back? :warranty:
So sorry for the 'jack Roy! :offtopic: I'm sure Bailey will clean this up soon enough... :goofy:
mods no need to delete anything, I luv utes just as much as bikes :fing02:
I really like the new Ford performance utes about to be released here in AUS this one is the V8 we also get a turbo six.
http://img222.imageshack.us/img222/67/sp5pk7.jpg
Roy, long time no post! I realize it's winter down there now, do you guys get much snow?
I' curious to know how the front end's holding up, if you still love it, etc?
:beer:
:beer:
Excuse me I have been caught up of late playing at the track with my CBR1000RR which takes allot of my time, we only get snow in 2 places whole of Australia so you can ride all year round here.
Because it has been taking up allot of my time I'll post some pics of the CBR1000RR which I'm always adding parts too as you do.
Since this pic I have removed the Ohlins ttx shock as I didn't like it & fitted a WP shock & front rotors have been upgraded to 320mm Galfers (04/05 standard are 310mm)
http://www.vfrdiscussion.com/forum/uploads/1219729714/gallery_2353_2169_100100.jpg
http://www.vfrdiscussion.com/forum/uploads/1219729714/gallery_2353_2169_50388.jpg
The VFR1 is still going strong & the R1 front end has never let me down, in fact the brakes & handling are so good there isn't anything I can do to improve it. I did have some 6 pot R1 calipers to fit but didn't bother due to the bike already will out brake the tire & I use race rubber for a front tire. Nothing upsets the front end pot holes, bumps, ripples, dirt I have never had one front end slide since the install & the best part is even with so many adjustments since finding a setting I like there hasn't been any need to add clicks of anything.
It's strange with the talk of the "maybe" new V5 or whatever VFR because the only improvement for me would be the few extra hp, but unless I'm doing 200kph+ I see no need for that. I have fitted the Motard headers which made a great improvement on smoothing out power delivery & you don't even notice VTEC except for the induction noise so driving out of turns is much smoother (dyno map bellow).
Some updated pics.
http://www.vfrdiscussion.com/forum/uploads/1219729714/gallery_2353_2169_20303.jpg
http://www.vfrdiscussion.com/forum/uploads/1219729714/gallery_2353_2169_291924.jpg
http://www.vfrdiscussion.com/forum/uploads/1219729714/gallery_2353_2169_14355.jpg
http://www.vfrdiscussion.com/forum/uploads/1219729714/gallery_2353_2169_46138.jpg
Nut shell: for everyday riding, touring, full sports riding, pillion comfort there is no better bike, I can do 2500kms of twisty mountain roads in 3 days & still dance a jig at the end & I'm no spring Chicken :fing02:
Looks great Roy, all of it!
Any chance you could post your details as far as your elevation above sea level where the map was tuned, what the weather was like that day(and maybe the map too)?
I am putting my 99 headers on this winter and would like to get my hands on a bunch of maps to play with.
hey roy, how'd you solve the brake problem in the end? Any pics of the spacers?
Man, the Vtec sure puts a nasty wiggle in the torque and HP curves. :blink:
Fantastic looking bike you've got there, Roy! :fing02:
Very, very nice! :fing02: 111 rwhp is now the highest credible rwhp figure I've seen for a VTEC. Congratulations.
Since you've got a rearstand, have you considered removing the center stand? You could knock off an additional 3 lbs. by doing so. Not carrying around the tool kit would be yet another 3 or so lbs.
I'm still waiting for somebody to modify the internals of the engine. I'm sure there are many people with the talent to bore out the cylinders (for a total displacement of 830-840 cc's) and then drop in higher compression pistons, cams with more duration and/or lift, etc. If you just got the big bore kit, that alone would probably put you near 120 rwhp. :fing02:
Once again, job well done.
this is a rad install!
I'm wondering if you could post some specifics? Like what front master cylinder you used? And did you use the plain 50mm convertibar, or a bike specific version?
You mentioned you were going to post more specifics... any ETA on that? I'm looking to do the same conversion and would love to pick your brain!!!
Jeff
Jeff
Hey Jeff, Roy has sold this bike but the front end lives on, on a mint 4th Gen VFR750 owned by VFRD member Parker. I'm sure he (or Roy) would be happy to elaborate, will see if I can shake one of them out of the tree, or just PM Parker.
Roy currently rides a 2009 CBR1000RR with a few of your more typical mods like Ohlins R&T forks, but I reckon a VFR1200 is going to get the zRoYz treatment in the near future...
Thanks Phantom!
You did this conversion too, correct? What front MC did you use?
In my research I found these bore sizes:
R1 = 14mm
954 = 17mm
929 = 19mm
SP1 = 19mm
SP2 = 17.5mm
Wondering what folks have used? If I use R1 calipers, I'd like to keep proper brake feel.
IIRC the R1 MC/perch doesn't have a brake switch, so I'd have to figure that out.
Thanks in advance-
R1 = 14mm
954 = 17mm
929 = 19mm
SP1 = 19mm
SP2 = 17.5mm
Thanks in advance-
Hi Raoul
Like Muz says, I am the proud and totally chuffed owner of the R1 set-up Roy built for his VTEC. It's been on the bike jsut over a year now, and I've done several big tours with the OzVFR crew, including a 12-day marathon in Tasmania (Godzone for Oz motorcyclists). I ranted and raved about it on my first ride home with it, and the more I ride it the better it gets (see also the pics in that thread).
Specifics - the m/cylinder is off an RC51 (SP1). I've still got the OEM clutch m/cyl on so it looks a bit odd, but so what. AFAIK the Convertibars are the 50mm and are a way way better thing than HeliBars as they're adjustable every which way. One tricky bit was getting the wheel and brake rotor spacing right as the CBR954 lower/ SP1 upper triple clamps are different to the spacing you get with the stock R1 triple clamps.
Any more questions feel free to ask away, but maybe PM me and I'll reply quicker.
Best of luck.
Picture Parker Please! :fing02:
Here you go Kev! Parker's bike after the R1 front end went onto it (lifted from the topic he linked in his reply, g'day Steve).
http://www.vfrdiscussion.com/forum/uploads/1247012703/gallery_1160_4785_343692.jpg
Raoul, mine is set up with the 2004 R1 master cylinder (got a VTR1000F clutch master cylinder, with Beringer reservoir kits for each side. My brake lines are HEL custom made (two equal length lines from master to calipers). CBR929 lower triple, and I have both CBR929 and SP1 upper triples, still haven't finalised the cockpit set-up so not sure which I'll use.
My clip-ons are 4-piece Epro billet items (Japanese top-shelf Yamaha parts specialist). They are 25mm higher than stock R1 position. My bodywork and riding position are more sportsbike than VFR so I don't have clearance problems.
The 2004 R1 master cylinder perch definitely has a brake switch (mine came from the US so same spec as you'll find locally).
A few HERE, and a couple more HERE, including a shot from a beach somewhere in Tasmania of three bikes (a 750, a 99 800 and an 02 VTEC) all featuring Roy's handiwork...
[image: Attached Image: FrankenviffersOnTheBeach.JPG]
Awesome guys, Thanks!!! :fing02:
+1!!!!! Thanks a ton! I've started collecting parts... Still deciding on specifics, but this helps a bunch!
-Jeff
Another reason to love VFRD. A two-year-old thread ignites another man's passion and we're off again!
Good stuff.
Why do I have a feeling that a couple VFRD people are going to get into a bidding war on ebay now.
Well front ends r readily availible. I got nearly the entire setup for justover $600. Now i gottafigure out how to make the abs workwith the new front end.
End of thread · 63 posts recovered Wayback Machine snapshot 25 Mar 2011
