If you wish to enjoy a light weight sport touring VFR you're going to
have go it alone because sport touring riders don't complain loud
enough about weight gains for Honda to reverse the weight gain trend
you see in today's market... its a crying shame too because a lighter
motorcycle will generally perform better due to a superior power to
weight ratio and because, all else being equal, a lighter motorcycle
will generally handle better than a heavier one. In high-performance
motorcycles, lighter weight is associated with advanced technology,
good design, and more expensive and exotic materials, while a
motorcycle whose weight is greater than expected can be perceived as
lacking these good qualities.
I've removed 33 pounds on Mr.RC45 since 98 with about 25K in tasty
items such magnesium wheels, titanium exhaust, CMC rotors, magnesium
triple clamps, Carbon Fiber fairings, Shorai battery, etc etc etc....
1 BLS magnesium Triple Clamps with 35mm offset... $1,200
[image: 1922147049_a35b7d3a42_o.jpg]
2 Ohlins FG310 Superbike Forks... $1,500
[image: 1922123823_3a08c7852c_o.jpg]
3 BLS tank bag platform... $50
[image: gallery_3131_51_15864.jpg]
4 Ferodo Ceramic Matrix Composite Front Disc... $2,300
[image: 3193188896_af6966746c.jpg]
5 Brembo billet radial Front Calipers... $1,500
[image: 3193188896_9d34585b46_o.jpg]
6 BLS Magnesium radial caliper mounts... $1,000
[image: 833790051_b85a11c78b_o.jpg]
7 Marchesini Magnesium 3.5x17 Front Rim that was owned by Wayne Rainey
when he sponsored Jimmy Felice YZ250R... $500
8 BLS 7075 T6 aluminum Front Axle... $350
[image: FortalAxleComparo.JPG]
9 BLS 7075 T6 Bar Risers... $450
[image: RC45BarsCables.JPG]
10 Brembo radial Front Brake master cylinder $275
[image: 1464360262_52e0a40359_o.jpg]
11 Brembo billet radial clutch master cylinder $375
[image: gallery_3131_51_7998.jpg]
12 Lockhart Phillips Quick Throttle Delrin throttle barrel $150
[image: 1463836757_202fd8a6a3_o.jpg]
[image: 1464360262_25f4110ef2.jpg]
13 Taper Steering Head Bearings... Koyo 39207JR-2 15.75 ea
14 Lockhart Turn Signals... $50
[image: 2543593243_83cdc9c5d6_b.jpg]
15 QB Carbon Front fender...$150
16 BLS K&N Air Cleaner... $60
[image: RC45KNfliter.JPG]
17 BLS modifed LED Tail lights... $150
[image: RC45LEDStopLight.JPG]
18 BLS Carbon Fiber Mirror covers... $100
19 Zero Gravity Dubble Bubble Wind Screen... $150
[image: HarleyShop03.jpg]
20 BLS Aluminum tank bracket... $100
[image: RC45AluminumTankBracket.JPG]
21 BLS T47 Temper Foam Seat and black canvas cover... $85
[image: 3221610268_46d505cd88_o.jpg]
22 BLS Ball bearing Rear Sets with Mil Spec rod ends... $550
[image: gallery_3131_51_90260.jpg]
23 Ohlins Rear Shock... $680
[image: gallery_3131_51_19326.jpg]
24 BLS 7075 T6 aluminum Ride height adjusted with nut... $150
[image: gallery_3131_51_98328.jpg]
25 BLS 4130 chromoly NL5 Rear Axle Mod with nut... $500
[image: gallery_3131_51_18755.jpg]
26 BLS 7075 T6 aluminum kick stand...$500
[image: RC45SideStandComparo..JPG]
27 BLS modified steel 525 ZX7R sprocket... $250
[image: gallery_3131_51_14811.jpg]
28 BLS Carbon Fiber Exhaust Can... $350
[image: 1438376909_43955a4877_o.jpg]
29 BLS 7075 T6 aluminum end cap with 90 dba stamp... $250
[image: 526545754_fd3267150c_o.jpg]
30 3 spoke Marchesini magnesium 6x17 Rear Rim from Freddie Spencer's
RC30...$600
[image: 315048023_c2710a3b99_o.jpg]
31 QB Carbon Fiber Tail Cowl with BLS access panel... $450
[image: 1922123781_677258a3fa_o.jpg]
32 Titanium exhaust hand crafted out of Akrapovic parts by Rob
Lindeman (RC45 owner)...$2,500
[image: 3000531780_56d0858308_o.jpg]
33 BLS Billet aluminum rear caliper mount... $500
[image: gallery_3131_51_43434.jpg]
34 Brembo billet 4 pot Gp rear caliper... $500
35 Speigler billet rear master cylinder... $350
36 HRC swingarm upgrade with BLS home made machine parts... $5000
[image: gallery_3131_51_1405.jpg]
37 Speedcell 1 lb 6 oz battery replaced 7 lb stock battery $250
[image: gallery_3131_51_71356.jpg]
38 QB Carbon all carbon fiber fairings $1,200
[image: RC45_QBcarbonHRCpart.JPG]
39 Sicom Ceramic Matrix Composite disc only weights 7oz... $500
[image: CMCRC45Disc1_zpscb04d098.jpg]
[image: CMCRC45Disc2_zps9bca6e90.jpg]
