Did a little more work on a public holiday last Monday and thought I'd post here to document the changes for anybody that may be interested in doing similar modifications to their's.
Difficult to find a high-level link pipe for the VFR, but I managed to get one from Predator in the UK (not the greatest quality or fit & very poor customer service, but after a bit of cutting & bending - it worked).
I was able to fit a full titanium silencer (at 1kg it weighs a fraction of what the link pipe does) made by Trickstar in Japan. Fortunately no modification to the silencer was needed at all.
Just waiting on a badge from them. I used some spare Akrapovic springs and clamp to secure the silencer to the mid pipe. I used a heat gun to bend the rear fender inward and a dremmel to cut a small section of the underside of the side panel. There's no interference at all and the silencer is well secured now.
[image: DSC_3945_zps1050687f.jpg]
I got some CBR900RR rear sets from Ebay. They fit with a standard RC51 heel plate used to space a CRF250 rear master cylinder far enough that it clears the frame and is in the right position for the pivot pin.
I needed to find a suitable eye bolt & do a little cutting & drilling, but it all works fine now. Still awaiting a pressure switch / banjo bolt so I can remove the old master cylinder and fit the brake hose.
[image: DSC_3943_zps70c4fa49.jpg]
Right side rear set also fitted without much drama. Just needed to make a suitable spacer to bring the rod out from the sprined shaft's pivot and also to allow the side stand cover to be retained (With just a little trimming off the top).
I will be putting flanged M6 nuts either side of the splined pivot to prevent twisting, but this is working fine now.
As a contingency plan I could still use the original shift lever if this doesn't last well - but would prefer the adjustability there is now. I have a couple of spare pivots in case this solution doesn't last well.
Also missing a left threaded lock nut, which I borrowed for a friend's RC51, but will source one from Honda.
[image: DSC_3941_zps4e6d5da3.jpg]
Fitted a set of convertibars and now there's no interference with the fairings at all. Positioning is pretty much same as original with wider bars. I'll adjust more later.
For now I've opted to keep the RC51's clutch master and a Brembo RCS 19 brake master. Still on the fence about fitting RC51 kill switch & starter with race style throttle, or leaving with original right side switch gear.
If I change, I'd lose the ability to switch lights on and off. Not something I use usually but if the battery gets flat this is useful. I suppose I could always pull a fuse for the lights in case of emergency.
[image: DSC_3948_zps22eed4ac.jpg]
Still haven't fitted brake lines for the front. I wanted to get the handlebars sorted first, so I can decide on exact routing and line lengths, then buy the components to make them...
That should come soon.
I've used the original cables which just fit. Longer ones I received from convertibars are of the wrong dimensions & lengths and could never work on a VFR, maybe there's something they can do.
[image: DSC_3951_zps1fac84f4.jpg]
I've also bought an NSR250 MC28 swing arm assembly for $200. The eccentric assembly is of same dimensions as the VFR and the brake rotor mounts are same too. Some research shows that the sprocket carrier size is same as an RC30's; in fact pretty much everything is of same dimensions as RC30, except the spacer, which is same as NC30/35, etc. As it's the same sprocket carrier size as the RC30's - this means getting 530 sprockets shouldn't be too difficult, even off the shelf here in Japan. I'm keen to lose the ugly cush drive housing. As RC30, RC45 & NR750 didn't have a cush drive, the VFR doesn't really need it either...
[image: 600x400-2014071101039.jpg]
I've also possibly located an underslung kit from Tyga which I can use with parts from the MC28 assembly, in combination with the original VFR750 swing arm &some minor modification. Assuming I'm right, then I'll be able to replace the rear caliper with a muhc prettier gold Brembo 84mm P4 unit.
So once this assembly arrives and I find some time, I'll do some tinkering to see if it will all work in harmony.
I've also been in touch with Dymag and they can make wheels to fit the MC28 hub, so a set of these CA5's will be on the cards in a few months.
[image: CA5_SSA__35317132382772712801280_zpsdd34]
[image: LB-dymag_5spoke_carbon2.jpg]
Assuming this all comes together, I'll be asking a machinist friend to make me a few small parts including a titanium spacer & shaft lock nuts for the MC28 hub.
