Hey everyone, this is my first post here. I've just picked up a '98 VFR800 and I'm really excited by it. The previous owner bought it in '99 and then it has sat for a long time (after he put 40k miles on it) because he had 3 other bikes he was riding. He's done a lot of work getting the bike back up and running and it's 90% of the way there at this point, but we're getting hung up on one main thing. The rear brake caliper is locking up when you press the brake pedal, but I think it is the center piston that's locking. From my understanding of the system, this actually shouldn't be possible.
One of the things we've done is rebuild most of the brake system. We've rebuilt all the calipers with new seals and cleaned up all the pistons. We put speed bleeders in all the calipers and the PCV. We bled the system (I've never encountered such a complicated bleeding process, holy cow) fully. After that, we found that the rear caliper was locking up when you press the brake pedal, but bleeding the center valve or the PCV frees it. Pressing the lever doesn't duplicate the problem (in fact, I test rode it around the neighborhood using only the front brake and it worked fine). It doesn't matter if the bike is moving either, pressing the rear pedal engages the rear brake and it doesn't fully disengage; subsequent presses get it stuck more and more.
I haven't pulled the caliper off to determine which piston is getting stuck, but considering the center valve and the PCV release it, it has to be the center piston.
I've ordered a replacement PCV to see if maybe that fixes things. Due to other threads I've found, I initially suspected the SMC but that doesn't make any sense to me since it doesn't matter if the bike is moving or not, unless it's possible the SMC is not behaving correctly and is just allowing the brake fluid to flow through but not releasing it.
Actually, that makes me think of another possibility: the guy I bought it from isn't as methodical in disassembling things as I am, so he didn't mark any of the brake lines. This left us with 4 brake lines for the front left; he says he connected them back properly by looking at the shape of the curves in the lines; if they're connected to the SMC backwards, could it cause this issue? EDIT: Nevermind, it was doing that before they removed any lines at all.
I was up until 1 AM this morning ordering the parts I need for the bike (tires, lights for the dash, etc), so I haven't had a chance to look at the bike in person, but I'm really excited to get it on the road (I've got a couple long trips coming up that I'd much rather take this bike on, with fully Givi luggage, than my Ninja 500) as soon as I can. Thanks for all your help!
